Name of injection line in UDF
Old   December 20, 2016, 09:57
Default Name of injection line in UDF
pakk will become famous soon enough
In an injection file, the structure is:
Originally Posted by Fluent Manual, 24.3.12. Point Properties for File Injections
(( x y z u v w diameter temperature mass-flow) name )
In a UDF, I know how to access most of these parameters:
 x: P_INIT_POS(p)[0]
 y: P_INIT_POS(p)[1]
 z: P_INIT_POS(p)[2]
 u: P_INIT_VEL(p)[0]
 v: P_INIT_VEL(p)[1]
 w: P_INIT_VEL(p)[2]
 diameter: P_INIT_DIAM(p)
 temperature: P_INIT_TEMP(p)
 mass-flow: P_FLOW_RATE(p)
Is is possible to use the name in a udf? For example: I want to print the name of a particle stream that reaches a certain surface, so I wrote the UDF:
DEFINE_DPM_BC(showname,p,t,f,f_normal,dim)
 Message("%s\n",P_NAME(p));
 return PATH_ABORT;
This does not work because P_NAME(p) is not the correct macro here, but what is?
(I also asked this question to Ansys support, if they give a working answer I will post it here.)
pakk is offline   Reply With Quote
Old   December 20, 2016, 11:52
I received a quick answer from Ansys support: the "name" in each line of an injection file is optional, and is not used inside Fluent. Therefore it is not possible to use this name in a udf for Fluent.
Old   April 21, 2017, 07:58
Default Hello
Hayder
eaxhm1 is on a distinguished road
Hello Pakk,
Hope you are fine,
I read your replying about Attaullah post on the mass transfer for absorption using the UDF.
I really need your help please,
I am trying to do the absorption process (acetone liquid absorbs acetone vapor) but I have no ideas how I do it.
Please, could you help me with the UDF and the set of the model?
I tried to send you a private message, but I couldn't.
Regards,
Hayder
eaxhm1 is offline   Reply With Quote
injection problem Mark New FLUENT 0 August 4, 2013 02:30
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
