UDF for Wave Generation and UDF Compilation Error
Old   December 19, 2016, 01:50
Default UDF for Wave Generation and UDF Compilation Error
Engrsdm is on a distinguished road
Hi Guys,
I want to simulate waves in a numerical wave flume. I will use UDF for moving wall for wave generation. I came across the UDF for a moving wall in CFD forums given below.
#include “udf.h”
#include “dynamesh_tools.h”
DEFINE_CG_MOTION(oscillate,dt,vel,omega,time,dtime )
Thread *t;
face_t f; /* define the variables */
t = DT_THREAD(dt);
begin_f_loop(f,t) /* loop over each face in the zone to create an array of data */
vel[0]=-2;
end_f_loop(f,t)
I have two main problems.
1) I don't know how to generate waves of desired parameters i.e time period and height using that UDF.
2) The other issue is that when I want to compile UDF in fluent it gives error saying that " The UDF library you are trying to load is not compiled for the 3D on the current platform (ntx86). The system can not find the specified path "
Please guide me in this matter
I am using ANSYS 15.7 (32 bit)
Thanks
Engrsdm is offline   Reply With Quote
entropy generation with UDF mohammadkm Fluent UDF and Scheme Programming 22 June 10, 2020 23:37
Wave Generation via Flapping Wall UDF LenDawg0220 Fluent UDF and Scheme Programming 5 June 26, 2017 17:05
UDF Outputs dont match exactly for volumetric heat generation. nvarma Fluent UDF and Scheme Programming 3 May 23, 2016 18:41
UDF error for Heat Generation mame Fluent UDF and Scheme Programming 4 March 3, 2016 05:22
UDF for heat generation prince_pahariaa FLUENT 4 July 11, 2011 03:58
