How to convert the surface force to volume force on the interface in VOF model? |
November 24, 2016, 21:57 |
Peter Aestas
Rep Power: 12 |
Hi friends,
I am working on a arc welding problem using VOF model. I need to convert some surface force (pressure and surface tension) to volume force on the interface and add them on the momentum equations. In Fluent help, the volume force of surface tension that is added to the momentum equation has been given using the divergence theorem: 1.jpg But, i do not understand why. If i want to convert pressure to the volume force using the similar method, how to do it? |
November 28, 2016, 02:37 |
KirMaks
Rep Power: 9 |
Hallo,
it may be very tricky. As far as I remember from the theory, the force due to the shear is Stress*Area. You can use very thin elements aligned with the boundary and apply this force (divided with density) to the cell centres only in the first layer of the near boundary cells, but it will work if Your boundary is already known and meshed accordingly. You never have well defined boundary with VOF, so You need to identify the boundary (phase 1 = 0.5), somehow find the cells with the melted material on this boundary and their boundary neighbours, somehow get the tangential stresses on the cells (from Lorentz force or Marangoni stress) and apply them as volumetric sources. I'm afraid You will not get the working code for such complicated problem here. Good Luck and regards, Maks. |
November 29, 2016, 20:48 |
#3 | |
Peter Aestas
Rep Power: 12 |
Thanks for your reply,Maks.
I am trying to use the similar method to convert other surface forces into volumetric surface force by the following equation: 1jpg.jpg the surface forces multiplied by the gradient of VOF.(the detailed explanation was in Brackbill et al. (1992), which is also referenced by Fluent, but i have not fully understand . ) As to the free boundary, i have successfully identified it by using both the value of VOF((as you said, phase 1 >= a certain value larger than 0)) and the gradient of VOF (at the boundary the absolute value of gradient of VOF must be greater than a certain value.).By using these two conditions, the very first layer on the free boundary could be identified. Quote:
February 14, 2021, 03:42 |
#4 | |
ANOOP K UNNI
Rep Power: 9 |
Did you find a solution for the mentioned problem. I want to know how to convert the surface to volume source term. if you know,please share |
March 23, 2021, 21:13 |
Venkat Ganesh
Rep Power: 6 |
Hey I'm facing the similar issue as well. I've written a UDF for the source term but I'm facing issues with handling the scalars and vectors together. Did you figure out a solution?
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
