ERROR: "UNC path are not supported. Defaulting to Windows directory."
Old   November 22, 2016, 13:00
Default ERROR: "UNC path are not supported. Defaulting to Windows directory."
Spiker54321 is on a distinguished road
Hi all,
compiling my UDF gives me following error message:
That makes sense as I set up the fluent .cas file in Windows, put the files for the batch job into a Linux directory, and let it run in parallel mode on a Linux cluster. When I select my UDF.c file that needs to be built I can't change the directory structure to the linux structure. So how can I solve my problem?
Up to now I've compiled on my windows platform and just copied the libudf folder with all the other batch files into the linux folder. That worked perfectly fine.
After I've changed the UDF by adding DEFINE_DPM_UPDATE_SCALAR (for particle tracking) this is somehow not possible anymore. There are no compiling issues coming up but the function is not executed properly. Therefore, I think I need to let the UDF be compiled by Linux.
Does anybody know how to change the directory structure to the linux structure within ANSYS Fluent running on windows?
Spiker54321 is offline   Reply With Quote
[OpenFOAM.com] Problems on Windows 8/10 (Issue: path had Russian name) drifter OpenFOAM Installation 2 August 25, 2016 05:13
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
