Using Cell gradient Variables in UDF
Old   November 15, 2016, 16:25
Default Using Cell gradient Variables in UDF
avd28 is on a distinguished road
Hi all,
I'm trying to simulate diffusion of a species through a boundary wall in my system. I'm trying to set a user defined species mass fraction at the walls with a UDF using the DEFINE_PROFILE function.
The specified mass fraction is actually a function of the concentration gradient at the wall. Hence I need to use the cell variable macro C_YI_G, which stores the gradient at the cell wall.
The usage of this variable with pressure based solver involves using 2 seperate commands
set/solve/expert
and
(rpsetvar 'species/save-gradients? #t)
which I have already done.
I'm using a parallel system and a moving mesh and have included provisions for that in the UDF as well. The UDF is as follows
#include "unsteady.h"
DEFINE_ON_DEMAND(save2)
#if !RP_HOST
    save2();
    Message0("\n\n   Done! \n   You can check this through plotting the contours of user defined node memory (e.g. print on walls)\n");
#endif /*!RP_HOST */
void save2()
    Domain *domain;
    cell_t c;
    Thread *t;
    Node *v;
    int n;
    domain=Get_Domain(1);
    /*Store the mesh node coordinates in user-defined node memory, this data is used in the dynamic mesh*/
    thread_loop_c (t,domain)
        begin_c_loop (c,t)
            c_node_loop (c,t,n)
                v = C_NODE(c,t,n);
                N_UDMI(v,0) = NODE_X(v);
                N_UDMI(v,1) = NODE_Y(v);
                N_UDMI(v,2) = NODE_Z(v);
        end_c_loop (c,t)
DEFINE_PROFILE(conc_sink,t,i)
  cell_t c;
  face_t f;
  real cx;
  begin_c_loop(c,t)
  cx = C_YI_G(c,t,i)[0];
  begin_f_loop(f,t)
    F_PROFILE(f,t,i) = cx*0.003;
  end_f_loop(f,t)
  end_c_loop(c,t)
This code compiles and loads correctly, but when I try to initialize the problem, it crashes. I realize of course that an initizlializing a gradient variable at the beginning of a solution may pose some problems. Does anyone know how to deal with this, and also how to use such variables in a solution?
avd28 is offline   Reply With Quote
Old   November 18, 2016, 10:07
pakk will become famous soon enough
There is the clean but complicated solution, and the easy dirty solution.
Easy dirty: make sure that conc_sink is not called when you initialize. So unload the library before you initialize, or change the relevant boundary condition into something else, and change it back after you initialize.
Clean but complicated: Add a check in your code such that the gradient is only read if you have already initialized your data. Based on the Fluent manual, I would guess one of these three formats would work:
if (NNULLP(THREAD_STORAGE(t,C_YI_G))) {... }
if (DATA_VALID_P(C_YI_G)) { ... }
if (DATA_VALID_P()) { .... }
But I never tested this myself, so if you do, please tell me if which one (if any) worked.
pakk is offline   Reply With Quote
Old   March 9, 2020, 18:22
mahdi rostami
mahdi-united is on a distinguished road
hi i wrote a udf for getting the species mass fraction gradients by define_adjust and using the storing commands as follow:
DEFINE_ADJUST(gradient, domain)
Thread *t;
Thread **pt;
cell_t c;
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE);
real voidx, voidy, voidz=0.0;
mp_thread_loop_c (t,domain,pt)
if (FLUID_THREAD_P(t) && n_udm > 0)
Thread *tp = pt[P_PHASE];
begin_c_loop (c,t)
C_UDMI(c,t,0) = C_YI_G(c,tp,0)[0];
end_c_loop (c,t)
this code compile and initialize correctly without any error
but in calculating in 1st iteration appear the message "the f1 process could not be started" and fluent crashes.
Where do you think the problem is?
mahdi-united is offline   Reply With Quote
Old   March 9, 2020, 18:35
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what is it?
you dont use pDomain in your code
try DEFINE_EXECUTE_AT_END instead of DEFINE_ADJUST
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   March 10, 2020, 04:11
Default Code
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The code works fine. I wrote it and tested it at my end before sharing it. The issue is with the case not with the code.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 10, 2020, 09:08
mahdi rostami
Originally Posted by AlexanderZ View Post
what is it?
hi
why do i use the DEFINE_EXECUTE_AT_END??
i want to store species mass fraction gradients.
Old   March 10, 2020, 09:09
mahdi rostami
how to send my case to you?
Old   March 12, 2020, 20:13
Alexander
Originally Posted by mahdi-united View Post
hi
read manual first. stop wasting our time
ansys fluent customization manual
best regards
Old   March 14, 2020, 07:26
mahdi rostami
hi
i type this command but not work
solve>set>expert
reply yes to question keep memory from being freed?
and
how to store the species mass fraction gradients in fluent?
what is the its another command?
define macro, fluent, fluent - udf
Using UDF in fuel cell addon module qwe2077 FLUENT 5 February 12, 2015 04:25
UDF to record FLUENT solver variables... mariachi FLUENT 1 February 3, 2010 23:18
accessing upstream cell - UDF bohis FLUENT 0 April 7, 2008 06:12
UDF: Density Cell Gradient Vector Macros matteo FLUENT 0 December 1, 2007 13:14
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 11:22
