Trouble with Storing Values with F_UDMI
Old   November 8, 2016, 15:36
Default Trouble with Storing Values with F_UDMI
Joshua
jbo214 is on a distinguished road
I want to store some variables using F_UDMI so I can access them later, however I'm having issues with having Fluent store any data.
This is my test UDF:
#include "udf.h"
#include "storage.h"
#include "mem.h"
DEFINE_EXECUTE_AT_END(pos_write)
	real pos[ND_ND];
	int zone_ID;
	face_t f;
	cell_t c;
	Domain *d;
	Thread *t;
	zone_ID = 7;
	d = Get_Domain(1);
	t = Lookup_Thread(d,zone_ID);	// choose BC zone ID from BC panel in Fluent
	begin_f_loop(f,t)
			F_CENTROID(pos,f,t);
			Message("X = , %f\n",pos[0]);
			F_UDMI(f,t,0) = pos[0];
	end_f_loop(f,t)
The UDF prints out the accurate values for the x value of the face centroid in the console, but when I plot the data in the User Defined Memory, everything is just 0. I've double checked that I initialized enough UDM and that I am storing it to the correct index. I also verified that I am using the correct zone ID from the BC panel. I'm using this for a wall BC so F_UDMI is applicable here.
Any ideas?
jbo214 is offline   Reply With Quote
Old   November 9, 2016, 04:34
`e`
`e` is on a distinguished road
Fluent is a cell centred solver, and its postprocessing takes values from the cells (either directly, or linearly interpolating for node values). You'll need to apply the same value to the adjacent cell as well to visualise in Fluent with contour plots etc. The adjacent cell and cell thread is retrieved with:
c = F_C0(f,t);
ct = F_C0_THREAD(f,t);
`e` is offline   Reply With Quote
Old   November 9, 2016, 12:13
Joshua
Originally Posted by `e` View Post
... to visualise in Fluent with contour plots etc. ...
What about just a regular X-Y plot? I followed the steps in the manual and it doesn't seem to assign any values to adjacent cells. They just assign a value using F_UDMI.
/* Compute face temperature and store in user-defined memory */
begin_f_loop(f,t)
          temp = F_T(f,t);
          F_UDMI(f,t,0) = (temp - tmin) / (tmax-tmin);
end_f_loop(f,t)
Old   November 9, 2016, 13:03
Joshua
I changed my UDF to use the adjacent cell and cell thread. It seems to store the proper information now.
#include "udf.h"
#include "mem.h"
	real pos[ND_ND];
	int zone_ID;
	face_t f;
	cell_t c;
	Domain *d;
	Thread *t;
	Thread *ct;
	zone_ID = 7;
	d = Get_Domain(1);
	c = F_C0(f,t);
	begin_c_loop(c,ct)
			C_CENTROID(pos,c,ct);
			Message("x =  %f\n",pos[0]);
			C_UDMI(c,ct,0) = pos[0];
	end_c_loop(c,ct)
fluent, fluent - udf, f_udmi, udf
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 16:49
Loading Cell Values in Tecplot P1361 OpenFOAM Post-Processing 3 September 16, 2014 05:02
WARNINGS I don't want to have Gabriel Siemens 3 August 10, 2007 18:04
Plotting raw data values Wilesco Siemens 0 January 5, 2006 06:34
