UDF of time dependent pressure read value from a text file |
November 4, 2016, 10:19 |
zhichao.zhao
Rep Power: 10 |
Hallo, Friends.
I meet some problems when i write the UDF code for a time dependent pressure, which will added as the boundary conditions of outlet. I only have a table of pressure values with times, the function should work like : read the values of P from the file P.text each time step and distribute that on the outlet (outlet bc is varing with time). i try to use DEFINE_PROFILE and CURRENT_TIME macro. but there is not equation of pressure with time, only have fixed table. Anyone know how to add a profile to UDF will be appreciated. |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Problem in UDF time dependent vloumetric heat source | eng_yasser_2020 | Fluent UDF and Scheme Programming | 0 | March 30, 2014 08:07 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
