Problem in compiling UDF with ANSYS Fluent 17.1 and Visual Studio 14.0
Old   October 27, 2016, 06:03
Default Problem in compiling UDF with ANSYS Fluent 17.1 and Visual Studio 14.0
Spiker54321 is on a distinguished road
Hi guys,
I have a problem compiling my UDF file with the above mentioned software. The function contains a math header that needs to be used. Here the simple code:
#include "udf.h"
#include <math.h>
#define F = 100;
#define w = 0.85;
#define x_wheel = 0;
#define y_wheel = 0.4;
DEFINE_SOURCE(xmom_source,c,t,ds,eqn)
real theta, source;
real x_diff;
real y_diff;
real x[ND_ND];
C_CENTROID(x,c,t);
x_diff = x[0]-x_wheel;
y_diff = x[1]-y_wheel;
theta = atan (x_diff/y_diff);
source = F*(sqrt (x_diff*x_diff+y_diff*y_diff)*w)*(sqrt (x_diff*x_diff+y_diff*y_diff)*w)*cos (theta);
ds[eqn] = 2*F*(sqrt (x_diff*x_diff+y_diff*y_diff)*w)*cos (theta);
return source;
It should mimic the force of a paddle wheel on an open water flow as it is depicted in principle here:
And this is the error message:
..\..\src\PaddleWheel.c(17): error C2059: syntax error: '='
..\..\src\PaddleWheel.c(18): error C2059: syntax error: '='
..\..\src\PaddleWheel.c(20): error C2059: syntax error: '='
..\..\src\PaddleWheel.c(20): error C2143: syntax error: missing ';' before ')'
..\..\src\PaddleWheel.c(21): error C2059: syntax error: '='
..\..\src\PaddleWheel.c(21): error C2143: syntax error: missing ';' before ')'
I guess it has something to do with the math header that is not handled correctly. I already tried to follow the suggestions from the other threads but it didn't help. The big difference here is that the include files of Visual Studio 14 are distributed in another way than the previous versions. As far is I understood it right they are outsourced in a "Windows Kit" folder. How can I tell this to Fluent? I also tried already to copy the files to the VC\include directory of Visual Studio but that didn't help neither.
Unfortunately, I can't go back to an older Visual Studio Version as I need the current version for another program.
Please help me!
Spiker54321 is offline   Reply With Quote
Old   October 27, 2016, 06:33
`e`
`e` is on a distinguished road
Remove the equals signs and semicolons from your preprocessor directives because these are currently included in the compiler.
#define F 100
#define w 0.85
#define x_wheel 0
#define y_wheel 0.4
`e` is offline   Reply With Quote
Old   October 27, 2016, 10:09
Shame on me.
Problem solved!
Thanks!
problem with compiling udf through visual studio chem engineer Fluent UDF and Scheme Programming 2 August 17, 2015 11:46
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
