Help with UDF to calculate the bubble velocity for 2 phase gas
Old   October 18, 2016, 07:11
Default Help with UDF to calculate the bubble velocity for 2 phase gas
enass
enass massoud is on a distinguished road
Hi.
i am trying to develop UDF to calculate the bubble velocity for certain number of time steps for 2 phase gas-liquid slug flow in vertical pipe, and then calculate new inlet velocity and check if convergence is established between initial and calculated velocity. If convergence is established then stop solution and hence calculated velocity is the terminal bubble velocity. If not, then reassign new calculated velocity to boundary condition and repeat process until convergence is established. Any help please???
enass massoud is offline   Reply With Quote
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? EnronZhang STAR-CCM+ 1 December 19, 2013 09:41
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 19:29
Gas velocity Newbie Main CFD Forum 1 April 7, 2003 06:55
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
