October 11, 2016, 14:34 |
help me please
mahya
Rep Power: 10 |
hello i write this udf
now i want to add zeta zeta = (-0.2*(Temp-273.15)-72.8)/1000 but when i compile it in fluent show error that cant identify Temp can you help me? thanks #include "udf.h" DEFINE_PROFILE(slip_ncond_x,face_thread,i) // x velocity for non conductive wall { face_t f; cell_t neig; Thread *cell_thread; Domain *domain = Get_Domain(1); real vel,normal_magnitude,E_normal_x,E_normal_y,E_repai red_x,E_repaired_y; real NV_VEC(A); real mu=0.001003; real eps0=8.85e-12; real eps=80.1; //cell_thread=THREAD_T1(face_thread); cell_thread=THREAD_T0(face_thread); begin_f_loop(f,face_thread) { neig=F_C0(f,face_thread); // Repair E component values............................................ .................................................. ... F_AREA(A,f,face_thread); //Message("x is %g\n", A[0]); normal_magnitude=pow( pow(A[0],2)+pow(A[1],2),0.5); if ( NULL != THREAD_STORAGE(cell_thread,SV_UDS_I(0)) && NULL != T_STORAGE_R_NV(cell_thread,SV_UDSI_G(0)) ) { E_normal_x=ND_DOT(-C_UDSI_G(neig,cell_thread,0)[0],-C_UDSI_G(neig,cell_thread,0)[1],0,A[0],A[1],0)/pow(normal_magnitude,2)*A[0]; E_normal_y=ND_DOT(-C_UDSI_G(neig,cell_thread,0)[0],-C_UDSI_G(neig,cell_thread,0)[1],0,A[0],A[1],0)/pow(normal_magnitude,2)*A[1]; E_repaired_x=-C_UDSI_G(neig,cell_thread,0)[0]-E_normal_x; E_repaired_y=-C_UDSI_G(neig,cell_thread,0)[1]-E_normal_y; } else E_repaired_x = 0 ; //.................................................. .................................................. ........................ F_PROFILE(f,face_thread,i)=-eps0*eps*zeta_p*E_repaired_x/mu; } end_f_loop(f,face_thread) } |
October 11, 2016, 14:52 |
#2 | |
Sorin Munteanu
Rep Power: 14 |
If you could provide the following, I might be able to help: - your original UDF (or an equivalent that you can post) that compiles fine - the code that you intend to add and the location where you want to add it - the error message that you get Without such information, I might guess that the variable Temp is either not declared or declared in a different scope that the scope where it is using. If this were the case your error should be something similar with "Error: your_udf.c: line xx: Temp: undeclared variable". Without seeing your code I can just guess. Thank you Sorin Quote:
