is it possible to write post processing UDF or TUI commands to do following task?
Old   October 6, 2016, 20:39
Default is it possible to write post processing UDF or TUI commands to do following task?
Ash Kotwal
Ash Kot is on a distinguished road
my UDF is based on flow time in transient flow analysis, after 300 time step it generates new velocity value and inlet, outlet pressure value.
also on 300th time step, data is autosaved in .dat and .cas files.
is it possible to write UDF or TUI commands set, to create .xy plot files using fluent inbuilt post processing plots option. at 300th time step.
Ash Kot is offline   Reply With Quote
Old   October 7, 2016, 06:38
Bruno Machado
Bruno Machado is on a distinguished road
Can't you use a journal to do this? Or you could try using the Calculation Activities tab.
Bruno Machado is offline   Reply With Quote
UDF and text commands David FLUENT 3 June 27, 2022 00:10
FLUENT adjoint solution post processing? fangr FLUENT 0 April 13, 2015 12:15
Write UDF to add a sink term for PEM fuel cell design kitrax Fluent UDF and Scheme Programming 0 March 15, 2012 05:56
UDF for post processing mvee FLUENT 0 May 23, 2007 13:13
UDF interpretation trough TUI David FLUENT 2 March 18, 2005 15:26
