How to avoid running macro for every cell and use it once per time step?
Old   September 20, 2016, 10:52
Default How to avoid running macro for every cell and use it once per time step?
R J
Andrei
R J is on a distinguished road
Hello!
I am trying to solve following problem.
The DEFINE_SOURCE macro is used to add source term to a volume. This term is constant through whole volume and only varies in time.
The source term is calculated by a different function (F2) every time step based on the other model parameters.
The problem I encounter is if I save the source term as a real number in F2, then DEFINE_SOURCE macro calls the F2 for every cell within a single time step, thus significantly affecting computational time.
My question is whether there is a way to define the source term in the F2, so it is called only once by DEFINE_SOURCE macro or maybe there is a different way to make it happen only once within a single time step?
I really hope I was clear with my explanations and solution is somewhere there. Thanks to all reading and answering
R J is offline   Reply With Quote
Old   September 20, 2016, 11:07
Bruno Machado
Bruno Machado is on a distinguished road
The source term is read every iteration by Fluent, different than DEFINE_EXECUTE_AT_END, which is read at the end of each iteration if steady state or at the end of each time step if transient.
Not sure this solves your problem, but is something worth trying. In a DEFINE_EXECUTE_AT_END macro, create a UDM and define it as F2. In your source term, define the source = UDM you created, so in that case, the calculation will be done only once (at the end of each time step). When you initialize, do not forget to initialize this UDM as the value of the source for the first time step.
Bruno Machado is offline   Reply With Quote
Old   September 21, 2016, 06:33
Andrei
Royal_J is on a distinguished road
Thank you a lot.
That is exactly what I was thinking of!
Still I get an error when compile the UDF that for this UDM void cannot be converted to real, while in the UDF manual that is what they are doing
Will keep on investigating.
Thank you for the valuable advice once again!
Royal_J is offline   Reply With Quote
Old   September 21, 2016, 07:03
Bruno Machado
Originally Posted by Royal_J View Post
Thank you a lot.
why UDM void? can you shre the piece of code you are trying to implement so I can have a look at it?
