September 19, 2016, 11:11 |
#21 |
Rep Power: 27 |
Thank you for you answers, but I was trying to ask something different...
You said that the results you got were wrong. This means two things: * You got something on your screen; * You expected something else in you head. So my questions are: 1. What did you see on your screen after you did your 'failed' simulation? 2. What did you expect in your head. |
September 19, 2016, 13:21 |
#22 |
Onur Özcan
Rep Power: 12 |
Sorry for the late answer. I was busy
[QUOTE=pakk;618483]Thank you for you answers, but I was trying to ask something different... You said that the results you got were wrong. This means two things: * You got something on your screen; * You expected something else in you head. Yes, I agree with that. No, no there is nothing to be misunderstood actually I have to thank you for helping me out with CFD. 1) As I said, I saw that faces having wall BC conditions could not change with temperature. Because wall BCs has constant temperatures. That's why they could not change with time or on iteration manner. Problem I ask is here. Actually those faces need to act as complete cell zone temperature. 2) That's why the thing I expect is to see temperature change in those faces like other faces. So, it must be given initial temperature in those trivial faces (wall BC faces) and Hence, they will change with time and iterationally. |
September 19, 2016, 13:31 |
#23 |
Onur Özcan
Rep Power: 12 |
You said that the results you got were wrong. This means two things: * You got something on your screen; * You expected something else in you head. it could be perfect temperature distribution. But bottom face is wall BC and constant temperature (trivial face) it need to act like cell zone initial temperature. That's why I ask it. Is there any method to give initial temperature in wall BCs |
September 19, 2016, 17:10 |
#24 | |
Onur Özcan
Rep Power: 12 |
[QUOTE=Bruno Machado;618474]
I am still reading something, those wall BCs will be given initial temperature (t=0). For example t=0, T=323.15K, temperature will change as well as flow trough. DEFINE_INIT is the most proper ? right? |
September 20, 2016, 03:43 |
#25 |
Rep Power: 27 |
What do you want to describe on the walls? I can give many interpretations to what you are saying... The two most likely:
Interpretation A: The walls should be given an initial temperature, and afterwards the temperature should not be constant but Fluent should calculate what the temperature is. Interpretation B: The walls should be given an initial temperature, and afterwards the temperature should not be constant but should change in a way that you know. |
September 20, 2016, 04:30 |
#26 | |
Onur Özcan
Rep Power: 12 |
Actually those faces are not wall, but I have to give those faces some named selections. Thus, I have to give them wall. Then, now, those wall BCs need to act like its cell zone. But ı dont know how those faces (wall BCs) react (cooling down or heating up) in transient simulation That is, I have no prediction how those faces (wall BCs) act/react/ |
September 20, 2016, 04:40 |
#27 |
Onur Özcan
Rep Power: 12 |
[QUOTE=pakk;618559]What do you want to describe on the walls? I can give many interpretations to what you are saying... The two most likely:
Interpretation A: The walls should be given an initial temperature, and afterwards the temperature should not be constant but Fluent should calculate what the temperature is. So, First attahed image shows that those faces are constant temperature during time that I have defined. because of having wall BC Second image is to show how solid material has temperature distribution. I need to see like this at least. |
September 20, 2016, 04:41 |
#28 |
Rep Power: 27 |
Then it might be that you are just looking for the 'no flux' boundary condition.
In the boundary condition of you wall (I know it is not made of stones and so, but it is just a name), go to "thermal", and select "heat flux", and set "Heat flux (w/m2)" to zero. |
September 20, 2016, 05:05 |
#29 | |
Onur Özcan
Rep Power: 12 |
there is ''thermal conditions'' in wall tab. Heat flux=0 (adiabatic) convection (heat transfer coeff.=0 and free stream =300) (there is no interface, that's why there is no heat transfer), the thing I want to be Temperature = 323.15K (constant), here is the answer That's why, temperature is constant in all process or during time. |
September 20, 2016, 06:11 |
#30 | |
Rep Power: 27 |
So set the "thermal condition" on "Heat flux". Then you will no longer see a constant temperature. |
September 20, 2016, 06:22 |
#31 |
Bruno Machado
Rep Power: 13 |
sorry to say that, but before trying to solve your problem, you gotta grab a book and learn about boundary condition. Neumann, dirichlet and robin boundary condition. looks like you are trying to solve something you don't understand, and randomly trying things. invest some time reading about it, and i am sure you wont even need our help to solve what you want.
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 15:26 |
How I can introduce my power heat (W) in chtMultiRegionFoam? | aminem | OpenFOAM Pre-Processing | 32 | August 29, 2019 03:23 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
