Udf-c_yi
Old   September 3, 2016, 13:55
Default Udf-c_yi
Boh
Boh is on a distinguished road
Hi!
I need to write an UDf for the diffusivity of vapor, I'm writing it using the density of the air and multiplying it with the mass fraction of the vapor to the air [kgmoisture/kgair]. I don't know how to write this term because if I use the C_YI(c,t,i) macro it gives error since I haven't activated the species model (I'm trying to solve the problem using UDS)...any ideas?
Thanks!
Boh is offline   Reply With Quote
Old   September 5, 2016, 05:16
Bruno Machado
Bruno Machado is on a distinguished road
Originally Posted by Boh View Post
Hi!
Thanks!
if you are not using species model and using UDS instead, you probably need to save your mass fraction as a UDMI and correct it every iteration.
Bruno Machado is offline   Reply With Quote
Old   October 4, 2016, 11:21
Boh
Thanks for your reply....but I don't understand how I can express the mass fraction in order to save it in UDMI
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
