DEFINE_GRID_MOTION For a non rigid geometry
Old   August 14, 2016, 15:22
Default DEFINE_GRID_MOTION For a non rigid geometry
aero_cfd is on a distinguished road
I have a non rigid geometry, defined by a mathematical equation, which is deforming in time , I read that for this application DEFINE_GRID_MOTION is more suitable than Define_Geom , does anyone have an example UDF ,tutorials or more material to study and similar cases ?
I will be using the dynamic meshing as well , any clue would be appreciated .
Thank you all in advance.
aero_cfd is offline   Reply With Quote
Old   August 15, 2016, 19:36
How come that no one answer on here? wrong section ?
Old   August 16, 2016, 10:01
Aurelien Thinat
Aurelien Thinat is on a distinguished road
You are asking for something ANSYS already provides on its customer portal (UDF manual + tutorials).
You should start there when you are looking for tutorials.
Aurelien Thinat is offline   Reply With Quote
Old   August 16, 2016, 10:17
Yes , I already checked the ANSYS manual, they do not provide such tutorials regarding my case , they only have an example about a beam , what I am looking for is someone who has done an unsteady simulation of an deforming body , an airfoil in my case.
I hope this makes it a bit clearer .
Old   December 7, 2020, 13:25
Default DEFINE_GRID_MOTION Tutorial
Lagos
olalekan1986 is on a distinguished road
Were you able to get a suitable tutorial that addressed your problem?
olalekan1986 is offline   Reply With Quote
define grid motion, fluent, udf
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
How to scale and translate the grid of particle data and STL geometry Saidul Tecplot 1 January 11, 2015 22:15
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
