FLUENT UDF for Variable Thermo-physical Property Simulation
Old   July 25, 2016, 12:08
Default FLUENT UDF for Variable Thermo-physical Property Simulation
Nusair Hasan
nh.cryo is on a distinguished road
Hello All,
I am interested in simulating problems relating supercritical fluids (single phase, near the critical point) using ANSYS-FLUENT V16. The thermo-physical properties are a strong function of fluid pressure and temperature near this state. So, I plan to provide either a surface fit or a 2D Table look-up in the form of x = f(p, T); where x is the thermo-physical property in question.
In the past, I have used user-defined variable properties (density, viscosity, thermal conductivity, specific heat, drho/dp etc.) with ESI CFD-ACE+ (a SIMPLEC based solver). Not sure, how it's done (if possible at all) in FLUENT. I have checked the CFD-Online forum for this issue, but it appears to me that there is an issue related to specifying the specific heat.
Any help in this matter will be greatly appreciated.
nh.cryo is offline   Reply With Quote
Old   November 1, 2017, 01:46
Refik
rewol is on a distinguished road
Currently i am working with something very similar too. Trying to implement Chung et al. method for viscosity and thermal conductivity with high pressure effects in mixtures as UDF.
Method is pretty straight forward for single component i presume, since there would be no "mixture rules" required.
Chung et al. method is widely used for supercritical fluid simulations. But note that it would require to include density and the constant volume specific heat in the model, so you need to call them from FLUENT somehow.
Regards.
Alper
rewol is offline   Reply With Quote
udf code, udf density viscosity, udf specific heat
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
help with nucleat boiling simulation UDF for Fluent cloudnqh FLUENT 0 March 10, 2011 11:56
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 04:07
