Error UDF
Old   July 22, 2016, 06:28
Default Error UDF
ERMACORA Florian
flo90000 is on a distinguished road
Hello
I write some UDfs. I have some errors when I compile it and I don't know to resolve the last ones.
My code where I have this errors is:
#include "udf.h"
#include "math.h"
DEFINE_SDOF_PROPERTIES(valve2, prop, dt, time, dtime)
#if !RP_HOST
  prop[SDOF_MASS] = 0.016624115;
  prop[SDOF_IYY] = 0.000010947;
  prop[SDOF_ZERO_TRANS_X] = TRUE;
  prop[SDOF_ZERO_TRANS_Y] = TRUE;
  prop[SDOF_ZERO_TRANS_Z] = TRUE;
  prop[SDOF_ZERO_ROT_X] = TRUE;
  prop[SDOF_ZERO_ROT_Y] = FALSE;
  prop[SDOF_ZERO_ROT_Z] = TRUE;
  prop[SDOF_LOAD_M_Y] = -9.81*0.045*sin(DT_THETA (dt[1])*0.045);
printf("\n 3d : Update 6DOF properties DT_THETA_Z:%e, Mz:%e, Mass:%e\n", DT_THETA (dt)[1],prop[SDOF_LOAD_M_Z], prop[SDOF_MASS]);
#endif;
The errors which I have are:
valve2.c: In function valve2:
valve2.c:15: error: invalid type argument of -> (have Dynamic_Thread)
valve2.c:17:7: warning: extra tokens at end of #endif directive
Thanks for your help
flo90000 is offline   Reply With Quote
Old   July 23, 2016, 01:42
D.M
Davoud Malekian
D.M is on a distinguished road
your problem actually apeared in this line:
try to use prantesis for dt , cause the way you have used dt[1] seems to be that you have used it as an array!!(and thats wrong!) so type like this:
prop[SDOF_LOAD_M_Y] = -9.81*0.045*sin(DT_THETA (dt)[1]*(0.045));
and enother problem is that u shouldnt use semicolon after #endif
regards.
D.M is offline   Reply With Quote
