receive a fatal signal after run. please help
Old   July 21, 2016, 02:56
Exclamation receive a fatal signal after run. please help
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
Hi dude
i write the udf to re position the nodes on the wall . it's compile without any errors . but when i run the simulation , the error appear
Error: received a fatal signal (Segmentation fault).
this is my code :
DEFINE_GRID_MOTION(indown,domain,dt,time,dtime)
	face_t f;
	Thread *tf = DT_THREAD(dt);
	Node *m[11] ;
	Node *v;
	real x ;
	real y ;
	real l ;
	int n ;
	int i,j,k ;
	i = 0 ;
    /* set deforming flag on adjacent cell zone */
    SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
    /*Message ("no node update check");*/
	begin_f_loop(f, tf)
	f_node_loop(f, tf, n)
	    v = F_NODE(f,tf,n);
	    NODE_MARK(v) = 0;
	end_f_loop(f, tf);
    begin_f_loop(f,tf)
       f_node_loop(f,tf,n)
			v = F_NODE(f,tf,n);
			if( NODE_MARK(v) == 0 )
				NODE_MARK(v) = 1 ;
				m[i] = F_NODE(f,tf,n);
				i = i + 1 ;
    end_f_loop(f,tf) ;
	for ( j = 10 ;  j >= 0 ; j = j - 1)
		Message (" in down 1 \n");
		for ( k = 0 ; k < 11; k = k + 1)
			Message (" in down 2 \n");
			if(NODE_Y(m[k])<NODE_Y(m[k+1]))
				Node *temp = m[k+1];
				m[k+1]=m[k];
				m[k] = temp;
	for ( k = 0 ; k < 11; k = k + 1 )
				NODE_POS_UPDATED(m[k]);
				x = NODE_X(m[k]);
				y = 0.005 * sin( ( 100 ) * ( x - (0.02*time) ) ) ;
				l = 0.008 - y ;
				NODE_Y(m[k]) = 0.008 - (l/10)*(k) ;
any help ?
amirhosseinfardi94@gmail.com
AHF is offline   Reply With Quote
Old   July 22, 2016, 07:26
Bruno Machado
Bruno Machado is on a distinguished road
try to add intermediate messages to check where the code crash
Message ("1");
Message ("2");
etc
This will help debugging
Bruno Machado is offline   Reply With Quote
fleunt, segmentaion fault, udf
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 6 June 24, 2024 04:17
fluentError: received a fatal signal (Segmentation fault). thomaszhangjing Fluent UDF and Scheme Programming 11 January 13, 2021 10:37
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
FLUENT received fatal signal (ACCESS_VIOLATION) osamaghani FLUENT 2 March 31, 2012 17:15
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
