Help with DEFINE_CAVITATION_RATE macro
Old   July 1, 2016, 08:34
Exclamation Help with DEFINE_CAVITATION_RATE macro
rsedaaghi is on a distinguished road
I'm trying to use the DEFINE_CAVITATION_RATE macro with the tutorial.
#include"udf.h"
#define c_evap 1.0
#define c_con 0.1
DEFINE_CAVITATION_RATE(user_cav_rate, c, t, p, rhoV, rhoL, mafV, p_v, cigma, f_gas, m_dot)
   real p_vapor = *p_v;
   real dp, dp0, source;
   p_vapor += MIN(0.195*C_R(c,t)*C_K(c,t), 5.0*p_vapor);
   dp = p_vapor - ABS_P(p[c], op_pres);
   dp0 = MAX(0.1, ABS(dp));
   source = sqrt(2.0/3.0*rhoL[c])*dp0;
   if(dp > 0.0)
      *m_dot = c_evap*rhoV[c]*source;
   else
      *m_dot = -c_con*rhoL[c]*source;
I got some questions:
1. What is op_pres? (solved it stands for operating pressure!!! )
2. I don't get this: ABS_P(p[c], op_pres) shouldn't it be: ABS_P(C_P(c, t), op_pres) I mean what are the differences? (solved p[c] refers to shared pressure I don't the background for this but it seems that it differs from the simple old C_P(c,t)!!!)
3. How does ABS_P differ from ABS? (solved ABS_P stands for absolute pressure and it's a function with 2 arguments!!! As you know ABS is mathematical function which stands for absolute value!!!)
4. Does FLUENT run this macro for each cell? What I mean is: Does it do a loop on all cells when it uses this macro or does it call this macro for each and every cell?
5. How does FLUENT calculate or know about rhoV and rhoL? (solved when one introduces liquid phase (as phase-1) and vapor phase (as phase-2) to the code it uses liquid phase's density as rhoL and vapor phase's density as rhoV!!!)
Thank you.
rsedaaghi is offline   Reply With Quote
cavitation
Macro within a Macro beyonder1 Tecplot 1 September 4, 2015 19:33
How to use the thread_storage macro? lxlxlxt FLUENT 0 February 10, 2014 22:53
StarCCM+ Command line options and Macro execution isidp STAR-CCM+ 8 January 29, 2013 06:00
Macro problem cfddummy Siemens 1 April 9, 2007 13:37
Call a macro from a macro Flav Siemens 2 July 1, 2004 06:42
