how can I get rid of segmentation fault
Old   June 30, 2016, 13:37
Default how can I get rid of segmentation fault
LR
sabuj is on a distinguished road
Send a message via Skype™ to sabuj
I am a newbie in ANSYS FLUENT. So, a lot of things still make no sense to me. I have been browsing various sources for past 3/4 days for the issue but to no avail.
I have a very simple 3D geometry of a rectangular channel and I am trying to use a temperature dependent density function and use a udf. The geometry has only inlet, outlet and wall. The code:
#include "udf.h"
DEFINE_PROPERTY(density,c,t)
real rho_w, rho_f, rho_p;
real ci=0.01;
real temp = C_T(c,t);
rho_w = 838.466+1.4*temp-.003*temp*temp;
rho_p = 750./(0.001*(temp-319.15)+1.);
rho_f = ci*rho_p+(1-ci)*rho_w;
return rho_f;
Now although I can interpret this code, I keep getting 'segmentation fault' error.
Some questions have raised in my mind:
1) Is my code correct? does this thread pointer (t) represent the whole fluid domain?
2) Why do I keep getting this error?
3) If I replace those temperature dependent functions with some constants, the simulation runs and does not show the error message.
Someone please help me with the code.
sabuj is offline   Reply With Quote
Old   July 1, 2016, 07:34
Bruno Machado
Bruno Machado is on a distinguished road
#include "udf.h"
real ci=0.01;
return rho_f;
3) If I replace those temperature dependent equations with some constant values, the simulation runs and does not show the error message.
did you enable energy equation?
Bruno Machado is offline   Reply With Quote
Old   July 1, 2016, 13:30
LR
Yes, Mr. Bruno. I enabled the energy equation. I am using FLUENT 15.0
Old   July 2, 2016, 09:53
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
#include "udf.h"
real ci=0.01;
return rho_f;
some points :
use another name for temperature instead of "temp" , like "z" or any thing else
the path that you save your udf , should not have space in directory address .
for example
//c:new folder is wrong
//c:newfolder is right
and other thing is that why you use "." in this line :
after 750 and after 1 ?
AHF is offline   Reply With Quote
Old   July 3, 2016, 06:46
D.M
Davoud Malekian
D.M is on a distinguished road
Hi Sabuj,
i just checked your UDF and both interpret and compile worked well with it and nothing appeard as an error. (my geometry was just a fluid zone)
if u got fluid and solid in your geometry i think u should some how specify your fluid zone in your udf (i mean specify t) like:
if (FLUID_THREAD_P(t))
D.M is offline   Reply With Quote
udf density
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
ABL use of fixed shear stress leads to segmentation fault 11 cristopf OpenFOAM Running, Solving & CFD 1 December 23, 2016 17:57
Segmentation fault when running in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 8, 2015 09:12
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 18:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
