Help me with UDF code
Old   June 18, 2016, 03:46
Red face Help me with UDF code
ronnie wang
sdsuronnie is on a distinguished road
#include "udf.h"
DEFINE_PROFILE(velocity_magnitude, t, i)
real velocity;
real the_current_time;
face_t f;
the_current_time = CURRENT_TIME;
if ((the_current_time>=0.0) && (the_current_time<0.25))
F_PROFILE(f, thread, position) =-39.04*t*t+9.76*t;
if ((the_current_time>=0.25) && (the_current_time<0.3))
F_PROFILE(f, thread, position) =89.6*t*t-49.28*t+6.72;
if ((the_current_time>=0.3) && (the_current_time<=1))
F_PROFILE(f, thread, position) =0;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = velocity;
end_f_loop(f, t)
Tha above is the code , however when i try to interpret it, it has err
hope experts here can help me
best regard
Ronnie
sdsuronnie@gmail.com
thanks
sdsuronnie is offline   Reply With Quote
Old   June 18, 2016, 03:47
ronnie wang
it is an inlet velocity boundary condition
Old   June 18, 2016, 09:28
Michael Prinkey
mprinkey will become famous soon enough
DEFINE_PROFILE is called for an entire face thread...the "t" in the DEFINE_PROFILE macro at the top of the UDF. You *must* loop over all of the faces on the thread and set F_PROFILE for each face. That is happening in what appears to be vestigial code at the bottom there, but not in the conditional test.
Inside of your if statements checking the_current_time, you need to have those loops. And your are using the thread pointer t in your piecewise definition of the velocity, which makes no possible sense. I assume that should be the_current_time.
 begin_f_loop(f,t)
  F_PROFILE(f, thread, position) =-39.04*the_current_time*the_current_time+9.76*the_current_time;
end_f_loop(f, t)
mprinkey is offline   Reply With Quote
Old   June 18, 2016, 11:16
Thumbs up Thank you
ronnie wang
Thank you for your comments, really help me a lot
best regard
Ronnie
Brownian Motion UDF Code Confuser FLUENT 3 August 13, 2021 02:14
power law udf code b.p.v Fluent UDF and Scheme Programming 1 April 4, 2019 03:33
how to use UDF to obtain the thred of the interface between the liquid and the wall? hellowqy Fluent UDF and Scheme Programming 8 December 17, 2015 11:03
How to transfer a 2D UDF code into 3D? Jo_vivian_lee Fluent UDF and Scheme Programming 0 August 26, 2012 04:36
Sos!!! Udf code Jo_vivian_lee Fluent UDF and Scheme Programming 1 August 16, 2012 01:09
