FLUENT Parallel Problem (UDF)
Old   June 16, 2016, 04:49
Unhappy FLUENT Parallel Problem (UDF)
soheil radfar
soheilr is on a distinguished road
I am trying to use parallel for my UDF. But I faced this error.
I have checked different thing: 1. Using both ANSYS v14.0 and v16.2 2. Uninstall and reinstall ansys and also intel mpi. But unfortunately nothing happened.
I am new in UDF and need help about explaining and solving this error!
any advice will be appreciated.
King Regards.
Node 0: Process 5348: Received signal SIGSEGV.
Node 3: Process 5332: Received signal SIGSEGV.
Node 1: Process 5608: Received signal SIGSEGV.
Node 2: Process 6080: Received signal SIGSEGV.
unable to read the cmd header on the pmi context, Error = -1
Error posting readv, An existing connection was forcibly closed by the remote host.(10054)
received suspend command for a pmi context that doesn't exist: unmatched id = 2
received suspend command for a pmi context that doesn't exist: unmatched id = 1
received suspend command for a pmi context that doesn't exist: unmatched id = 0
job aborted:
rank: node: exit code[: error message]
0: DESKTOP-R8V9125: 2: process 0 exited without calling finalize
1: DESKTOP-R8V9125: 2: process 1 exited without calling finalize
2: DESKTOP-R8V9125: 2: process 2 exited without calling finalize
3: DESKTOP-R8V9125: 2: process 3 exited without calling finalize
The fl process could not be started.
soheilr is offline   Reply With Quote
Old   June 16, 2016, 08:55
`e`
`e` is on a distinguished road
This error occurs when the process is trying to access a variable that isn't available. What is your UDF code and did it work in serial?
`e` is offline   Reply With Quote
ansys 14, fluent, mpi, sigsegv, udf
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
problem with compiling boundary condition udf in parallel mode chem engineer Fluent UDF and Scheme Programming 11 June 29, 2015 07:23
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Problem with Parallel Fluent mohamed_ FLUENT 1 December 28, 2012 12:23
