Help whit this UDF
Old   June 15, 2016, 17:06
Default Help whit this UDF
Julio Herrera Venegas
Culio is on a distinguished road
hi guys, i am trying compiling this udf, but i get this error:
kernel32.lib(KERNEL32.dll) : error LNK2005Copied C:\Users\Dell\Desktop\memoria_ canal_austral\datos_experimentales\perfiles_salini dad/C:\Users\Dell\Desktop\memoria_ canal_austral\datos_experimentales\perfiles_salini dad\uuuu.c to libudf\src
udf_names.c and user_nt.udf files in 3ddp_host are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v160\fluent"\fluent16.0.0\sr c\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ")
1 archivo(s) copiado(s).
(chdir "libudf")(chdir "win64\3ddp_host")# Linking libudf.dll because of makefile user_nt.udf udf_names.obj uuuu.obj
Microsoft (R) Incremental Linker Version 12.00.40629.0
Copyright (C) Microsoft Corporation. All rights reserved.
kernel32.lib(KERNEL32.dll) : error LNK2005: ya se definió ReadFile en uuuu.obj
Creando biblioteca libudf.lib y objeto libudf.exp
libudf.dll : fatal error LNK1169: se encontraron uno o más símbolos definidos simultáneamente
udf_names.c and user_nt.udf files in 3ddp_node are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~1\v160\fluent"\fluent16.0.0\sr c\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ")
(chdir "libudf")(chdir "win64\3ddp_node")# Linking libudf.dll because of makefile user_nt.udf udf_names.obj uuuu.obj
Done.
Any clue?
this is the udf:
#include "udf.h"
int NPtsTm,NPtsData;
int DataIsRead = 0;
float *tmarr,*xarr,*yarr,*zarr,**Tarr;
DEFINE_ON_DEMAND(ReadFile)
int n,i;
float data;
FILE* fp;
fp = fopen("DataFile","r");
if ( fp!=NULL )
Message("Reading file n");
else
Message("Error in opening file n");
fscanf(fp,"%d %dn",&NPtsTm,&NPtsData);
Message("n");
Message("There are %d time entries and %d spatial entriesn",NPtsTm,NPtsData);
/* Dynamic allocation for 1D array */
tmarr = (float *) malloc(NPtsTm*sizeof(float));
xarr = (float *) malloc(NPtsData*sizeof(float));
yarr = (float *) malloc(NPtsData*sizeof(float));
zarr = (float *) malloc(NPtsData*sizeof(float));
/* Dynamic allocation for 2D array */
float *temp;
temp = (float * ) malloc(NPtsTm*NPtsData*sizeof(float));
Tarr = (float **) malloc(NPtsTm*sizeof(float *));
for(n=0;n<NPtsTm;n++)
Tarr[n] = temp + n*NPtsData;
if ( (tmarr==NULL)||(xarr==NULL)||(yarr==NULL)||(zarr== NULL)||(Tarr==NULL) )
Message("Memory allocation error n");
fscanf(fp,"n");
Message("n");
Message("The following is the %d time entriesn",NPtsTm);
for ( n=0;n<NPtsTm;n++ )
fscanf(fp,"%f n",&data);
tmarr[n] = data;
Message(" %fn",data);
fscanf(fp,"n");
for ( i=0;i<NPtsData;i++ )
xarr[i] = data;
fscanf(fp,"n");
yarr[i] = data;
fscanf(fp,"n");
zarr[i] = data;
fscanf(fp,"n");
Tarr[n][i] = data;
DataIsRead = 1;
fclose(fp);
/* Output check */
Message("n");
Message("The following is the %d coordinate entriesn",NPtsData);
Message(" %f %f %fn",xarr[i],yarr[i],zarr[i]);
Message("n");
Message("The following is scalar data for time entry # %dn",n);
Message(" %fn",Tarr[n][i]);
float GetData(float xf, float yf, float zf, float tm)
int n,nL,nU,i;
float tmL,tmU,data,dataL,dataU,sf,smin;
tm += 1.0e-7;
/* Find the time bracket */
nL = 0;
nU = 1;
tmL = tmarr[nL];
tmU = tmarr[nU];
if ( (tm>=tmarr[n])&&(tm<=tmarr[n+1]) )
nL = n;
nU = n+1;
tmL = tmarr[nL];
tmU = tmarr[nU];
break;
/* Find data at the lower and upper time bound */
smin = 1.0e30;
dataL = 0.0;
dataU = 0.0;
sf = sqrt( pow((xarr[i]-xf),2) + pow((yarr[i]-yf),2) + pow((zarr[i]-zf),2) );
if ( sf<=smin )
smin = sf;
dataL = Tarr[nL][i];
dataU = Tarr[nU][i];
/* Interpolate between lower and upper time values */
data = dataL + ( tm - tmL )/( tmU - tmL )*( dataU - dataL );
return data;
DEFINE_PROFILE(Tspec,tf,pos)
face_t f;
float tm,xf[ND_ND];
tm = RP_Get_Real("flow-time");
begin_f_loop(f,tf)
F_CENTROID(xf,f,tf);
F_PROFILE(f,tf,pos) = GetData(xf[0],xf[1],xf[2],tm);
end_f_loop(f,tf)
Culio is offline   Reply With Quote
Old   June 16, 2016, 08:34
`e`
`e` is on a distinguished road
kernel32.lib(KERNEL32.dll) : error LNK2005: ReadFile already defined in temp.obj
The name ReadFile is already used in another function. Rename your DEFINE_ON_DEMAND macro to a unique name:
DEFINE_ON_DEMAND(myReadFile)
`e` is offline   Reply With Quote
profile data, udf
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
Help! Delete the UDM codes in the UDF Messi Fluent UDF and Scheme Programming 2 January 28, 2014 10:01
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
