Error: Segmentation Fault - Fluent
Old   June 14, 2016, 14:13
Default Error: Segmentation Fault - Fluent
Braulio Uciel Alvarado Alcalá
uzziel01 is on a distinguished road
Hello!!
I'm trying to simulate Natural Convection inside a refrigerator. I have a polynomial to enviromental temperature and I've made a UDF to calculate the temperature inside the refrigerator and to calculate the "h" coefficient for convection using the correlation of Churchill y Chu.
Fluent interprets the UDF correctly, but when I'm going to initialize the solution a message appears.
Could anyone help me, please?
This is the code of de UDF.
DEFINE_PROFILE(h_constant, thread, position)
real tsuma=0;
real tavg;
real temp;
face_t f;
int contador=0;
real p,t_env;
real r,Cp,k,mu,vis;
real Pr;
real g=9.81, beta,L=0.43,Ts,Gr;
real Ra,Nu,h;
        cell_t c; /* Se declara una variable de celda */
        Thread *t_c;
        Domain *y;
        int refri_id=1;
        y=Get_Domain(refri_id);  /*    Indica el ID de la zona de la pared     */
                    /* Calculo de la temperatura promedio del dominio */
            thread_loop_c(t_c,y)
                begin_c_loop(c,t_c)
                    temp = C_T(c,t_c);
                    contador++;
                    tsuma += temp;
                end_c_loop(c,t_c)
                tavg = tsuma/contador;
                            /* Temperatura ambiente */
               p=CURRENT_TIME;
              if (p<=9000)
                 t_env=298.1+0.001334*p-0.0000001681*(pow(p,2))+0.000000000006433*(pow(p,3));
              else if (p>9000 && p<=69900)
                 t_env=302.1-0.00003154*p-0.0000000006091*(pow(p,2));
              else if (p>69900 && p<=106800)
                 t_env=-231.3+0.022*p-0.0000003451*(pow(p,2))+0.000000000002433*(pow(p,3))-0.000000000000000006474*(pow(p,4));
              else if (p>106800 && p<=158400)
                 t_env=311.9-0.00006337*p-0.0000000001965*(pow(p,2));
              else if (p>158400 && p<=198900)
                 t_env=40.92+0.00281*p-0.000000007524*(pow(p,2));
              else if (p>198900 && p<=241500)
                 t_env=287.7+0.0002514*p-0.0000000009*(pow(p,2));
                      /*     Correlación para h     */
                /* Cálculo para propiedades del aire a T=tenv */
        r=3.68909-0.0128308*t_env+0.0000148526*(pow(t_env,2));
        Cp=1017.11-0.131603*(t_env)+0.000300914*(pow(t_env,2));
        k=0.00318413+0.0000748721*t_env;
        mu=0.00000429617+0.0000000475835*t_env;
        vis=mu/r;
                        /* Prandtl */
        Pr=(Cp*mu)/k;
                        /* Grashof */
        /* L=43.5 cm */
        Ts=(tavg+t_env)/2.;
        beta=1./Ts;
        Gr=(g*beta*(tavg-t_env)*(pow(L,3)))/(pow(vis,2));
                        /* Rayleigh */
        Ra=Gr*Pr;
                /* Correlación de Churchill y Chu para Nusselt */
        Nu=0.68+((0.670*(pow(Ra,0.25))))/pow(1+(0.492/(pow(Pr,9/16))),4/9);
        h=(Nu*k)/L;
        begin_f_loop(f,thread)
                F_PROFILE(f,thread,position)=h;
        end_f_loop(f,thread)
        printf("Valor de h: %g\n", h);
uzziel01 is offline   Reply With Quote
Old   June 14, 2016, 18:42
`e`
`e` is on a distinguished road
This segmentation error occurs when you're trying to access a variable which isn't available. You'll need to identify the line of code which is causing this error. First, try replacing C_T(c,t_c) with 1. to check if the cell temperature is available across all cells. If the segmentation error disappears, then it's possible the cell temperature isn't available on the first time step for the DEFINE_PROFILE macro (apply a conditional statement in this case).
Note: if you're running this macro with the parallel solver then these looping macros only access the cells within the compute node's partition. Therefore, the average temperature calculated would not cover the entire domain. See the UDF manual for examples on communicating between compute nodes (message passing).
`e` is offline   Reply With Quote
Old   June 14, 2016, 19:35
Default Thanks
Thanks `e`
I've changed the value that you suggues me, but I have the same error yet.
I've change the value in F_PROFILE, to, but it's the same error.
Could you suggues me another thing to change?
Thanks `e`
Old   June 15, 2016, 08:25
`e`
Either remove lines of code until you find the cause of the error or add messages using the Message() function to help with debugging.
Old   December 9, 2016, 17:39
ali
alinik is on a distinguished road
Braulio,
I am having the same error.
Apparently this line is creating the problem:
thread_loop_c (t,domain)
Did you find a solution to your problem?
Originally Posted by uzziel01 View Post
Hello!!
real tsuma=0;
real tavg;
real temp;
face_t f;
int contador=0;
real p,t_env;
real r,Cp,k,mu,vis;
real Pr;
real Ra,Nu,h;
        Thread *t_c;
        Domain *y;
        int refri_id=1;
                begin_c_loop(c,t_c)
                    temp = C_T(c,t_c);
                    contador++;
                    tsuma += temp;
                end_c_loop(c,t_c)
               p=CURRENT_TIME;
              if (p<=9000)
        vis=mu/r;
                        /* Prandtl */
        Pr=(Cp*mu)/k;
                        /* Grashof */
        /* L=43.5 cm */
        Ts=(tavg+t_env)/2.;
        beta=1./Ts;
                        /* Rayleigh */
        Ra=Gr*Pr;
        h=(Nu*k)/L;
alinik is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
Fluent UDF Wall Shear Stress Segmentation Fault a1ananth Fluent UDF and Scheme Programming 3 February 24, 2015 04:23
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
