Facing Parse Error
Old   June 13, 2016, 04:07
Unhappy Facing Parse Error
KasrA
kasrakrd is on a distinguished road
Hi guys,may i have your help on this code ? :/
I faced this error ---> line 47: parse error
and this is my code :
#include "udf.h"
DEFINE_PROPERTY(cell_viscositynano,c,t)
double mu;
double h = C_T(c,t);
//mu = exp(3.003- 0.04203*h - 0.5445*1 + 0.0002553*pow(h,2) + 0.0524*pow(1,2) - (1.622/1))/1000;
mu = (-0.155 -19.582/h +0.794*1 +2094.47/pow(h,2) -0.192*pow(1,2) -8.11*1/h -27463.863/pow(h,3) +0.0127*pow(1,3) +1.6044*pow(1,2)/h +2.1754*1/pow(h,2))/1000;
real mu;
DEFINE_PROPERTY(thermal,c,t)
double mu_lam , k ,Pr ,Re ;
double z = C_T(c,t)- 273;
double a , b , c , d , f ,aa ,bb, cc, dd ,ee;
//double mu_lam;
double t = z + 273;
// u water
a = 98.75*log(z);
b = (-45.23)*log(z)*log(z);
c = (9.71)*log(z)*log(z)*log(z);
d = (-0.946)*log(z)*log(z)*log(z)*log(z);
f = (0.03)*log(z)*log(z)*log(z)*log(z)*log(z);
mu_lam = (-81.1+a+b+c+d+f)/1000;
Re = (997.1*1.3807*pow(10,-23)*t)/(3*3.14* mu_lam * mu_lam * 0.17 * pow(10,-9)) ;
Pr = mu_lam / (997.1 * 1.47*pow(10,-7));
aa = pow(1,0.7640); // volume fraction
bb = pow((0.384/47),0.369);
cc = pow((0.613/25),0.7476) ;
dd = pow(Pr,0.9955);
ee = pow(Re,1.2321);
k = ( 1 + 64.7*aa*bb*cc*dd*ee)*0.613;
real k:
Mesh location : C:\Fluent.Inc\ntbin\ntx86\LD0.8-2121
UDF location : C:\Fluent.Inc\ntbin\ntx86\properties-phi9
kasrakrd is offline   Reply With Quote
Old   June 13, 2016, 04:45
pakk will become famous soon enough
What is on line 47? And what is that line supposed to do according to you?
pakk is offline   Reply With Quote
Old   June 13, 2016, 07:00
KasrA
real k; and it defines type of variable "k" as real number
Old   June 13, 2016, 07:04
Bruno Machado
Bruno Machado is on a distinguished road
you defined it as a double first and now you are defining it as real (this does not make any sense).
you should " return k; ", not REAL k.
Bruno Machado is offline   Reply With Quote
Old   June 13, 2016, 07:06
(edit: in response to kasrakrd, not to Bruno Machado): No and mwah.
No: read carefully, your code does not say "real k;", but "real k:".
Mwah: if it would say "real k;", it would still a warning and probably also an error. The warning is because you already defined k as a double. And the error that I expect is because you can not define a variable after you use it.
And your UDF currently returns nothing. I guess that the value you want to use in your simulations is k, so probably you should add "return k" at the end.
Old   June 13, 2016, 07:07
KasrA
Originally Posted by Bruno Machado View Post
you define it as a double first and now you are defining it as real (this does not make any sense).
I changed it and i faced this :
line 47: function returning float returns double.
Old   June 13, 2016, 07:10
You can get rid of that warning by letting it return a float.
There are multiple ways for that, one of them:
return (float)k;
Old   June 13, 2016, 07:43
KasrA
Thank you Bruno Machado and pakk
problem solved
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
