Parallel Processing Error (UDF)
Old   June 11, 2016, 18:06
Default Parallel Processing Error (UDF)
soheil radfar
soheilr is on a distinguished road
I am trying to use parallel processing for my udf simulation but I have faced with following errors:
- received suspend command for a pmi context that doesn exist unmatched id 1
- the fl process could not be started fluent
- An existing connection was forcibly closed by the remote host
Previously I did not have such an error with this UDF!!!
Please Help me with this error
soheilr is offline   Reply With Quote
Old   June 11, 2016, 18:33
`e`
`e` is on a distinguished road
What's your UDF code? Do you get the same error in serial mode or parallel with one process?
`e` is offline   Reply With Quote
Old   June 11, 2016, 18:37
soheil radfar
There is no problem in serial mode.
Old   June 11, 2016, 18:39
`e`
We can't help if you don't provide your source code to spot the error with.
Old   June 11, 2016, 18:44
soheil radfar
Here is the UDF!
King Regards
Old   June 11, 2016, 21:47
`e`
The .zip file is corrupted. Simply copy and paste the code within [CODE] tags.
Old   June 12, 2016, 04:52
soheil radfar
The code is nearly 100-A4 pages! I have to attach it!
Old   June 12, 2016, 04:59
soheil radfar
I double checked the zip file!
There was no problem and unzipped well!
Old   June 12, 2016, 05:46
`e`
Ok, I've unzipped the file using 7-Zip (Windows was giving an error). There are 4241 lines of code there, you'll need to find where the problem is by debugging. First, find the functions which are causing the issue (comment out or disable them one by one). Second, find the line of code(s) by printing messages to the screen with Message().
Old   June 12, 2016, 08:15
soheil radfar
In my opinion, this code is fine at all; since it is an official code of ANSYS FLUENT and previously checked by other researchers. Also, I used this udf in parallel mode about 3 months ago without error, on another system. But I do not have access to that system anymore !
Old   June 12, 2016, 16:52
`e`
I saw the UDF was last updated for Fluent 6.3 which was released in 2006. It's likely there's been changes in ANSYS Fluent in the last 10 years which has caused the UDF to break. Have you contacted ANSYS to see if they've released a new update? Try running an older version of Fluent (the one that worked for you in the past). Otherwise, it'd take a while to go through this code and sort out yourself.
Old   June 13, 2016, 19:36
`e`
There's another user, blgypeng, who is now asking about this UDF as well. It sounds like the issue is with how Fluent is sending and receiving data from the GUI.
fluent, parallel processing, udf
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 20, 2015 00:41
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 07:17
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
