UDF for an annular disc.
Old   May 26, 2016, 15:14
Default UDF for an annular disc.
Alex Skerhut
alexskerhut is on a distinguished road
Hey I have an annular disc whose radius goes from 5mm to 10mm and I need to write a UDF as a function of angle and radius in cylindrical co-ordinate system. I will use the DEFINE_PROFILE function but I am not able to understand how to in corporate the radius and the angle variation in disc.
Kindly help, I have searched a lot but not able to figure out the solution.
alexskerhut is offline   Reply With Quote
Old   May 26, 2016, 20:18
`e`
`e` is on a distinguished road
Are you running Fluent with Cartesian coordinates? You can convert between cylindrical to Cartesian coordinates with (x,y) = (r cos(theta),r sin(theta)). Note: you need to account for the displacement of the circle if it's not centred about the origin.
`e` is offline   Reply With Quote
Old   June 3, 2016, 03:27
Alex Skerhut
Yes, I am running fluent with cartesian coordinates. My global coordinate system is 10mm above the centre of the annular disc and I want to define heat flux using DEFINE_PROFILE as a function of radial distance and angular position. Heat flux if of type = r - sin(theta) form multiplied by some constants. I am unable to write UDF for such function in cylindrical coordinates. Also theta is the angle measured from which of the axis. I need to measure theta in anticlockwise sense from the x axis along z axis. Please help me writing the UDF for the above function.
Please help me and thanks in Advance.
Old   December 30, 2017, 07:12
sooraj546 is on a distinguished road
DID u find a solution for it @alexskerhut?
sooraj546 is offline   Reply With Quote
rotary parts, rotating boundary, rotating disc, rotating disk, udf code
udf for valve closing a pipe using dynamic mesh chem engineer Fluent UDF and Scheme Programming 2 May 13, 2017 10:39
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 11:29
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
fan driven flow, Fan BC validation (getting lost) soonic OpenFOAM Running, Solving & CFD 0 July 7, 2013 20:16
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
