May 23, 2016, 12:45 |
UDF for periodic boundary condition
Srivatsan
Rep Power: 10 |
Hello
I want to write a UDF for periodic boundary condition in Fluent. I have to take temperature and velocity data points from outlet and feed it back to inlet. I was going through the fluent manual and found that there are two functions, DEFINE_PROFILE and DEFINE_EXECUTE_AT_END. I am not sure if I can write a function within a function as required by this case. If anyone else has encountered the same issue, could you please throw some light. |
May 23, 2016, 17:45 |
Rep Power: 18 |
Have you tried using the periodic boundary condition, or do you need to use a UDF? Instructions: http://www.cfd-online.com/Forums/flu...-tutorial.html
May 23, 2016, 18:23 |
Srivatsan
Rep Power: 10 |
Thanks for the reply ...I am aware of the periodic bc ...but want to do it as a udf due to some constraints in my model ...
June 20, 2016, 10:04 |
Hi Srivatsan,
have you achieved any success? If yes, I would highly appreciate if you could explain your final workflow. Thanks in advance! |
write a UDF to give a velocity boundary condition at an interior face | Tharanga | Fluent UDF and Scheme Programming | 19 | August 5, 2018 04:29 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 05:09 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Boundary Condition Types Using Scheme and UDF | Nasir | FLUENT | 0 | September 15, 2008 21:54 |
UDF : boundary condition ID | Flav | FLUENT | 4 | June 28, 2001 09:52 |
