May 13, 2016, 06:54 |
Evaporating Multicomponent Spray
Simon
Dear all,
I have looked thoroughly at forums to try and find a solution for my problem, but sadly it failed. I am trying to simulate an evaporating ammonia/water spray. I have a long rectangular duct with 970 C hot flue gas flowing upwards (approx 5 m/s) in the Y-direction. The particles are injected in the Z direction and is supposed to evaporate into both ammonia and water. The initial conditions for the spray is specified by a particle file from previous simulation. A compressed air stream(2,5bar) directly behind the injection point accelerates the particles. Radiation is included with the DO-model and the k-e standard model is used to account for turbulence. I am using the multicomponent law for the particles, which doesnt seem to take the change of particle mass and diameter into consideration (atleast when i plot the particle trajectories after reaching convergence). In order to calculate the evaporation rate of both species, I implemented an UDF using the DEFINE_DPM_HEAT_MASS function. I use the same code as the example from the UDF folder. In order to change the diameter of the particle as it evaporates, i implemented another UDF using the DEFINE_DPM_LAW. Both codes are compiled without issues (using Visual Studio Express). However, after convergence I notice:
I would greatly appreciate any suggestion as to why the UDF's don't have the desired impact on my simulation. Best Regards Simon The two UDF's are as follows: /************************************************** ***************** UDF the models a custom law for evaporation of species ************************************************** *****************/ #include "udf.h" #define REMOVE_PARTICLES FALSE DEFINE_DPM_HEAT_MASS(multivap,p,Cp,hgas,hvap,cvap_ surf,dydt,dzdt) { int ns; Material *sp; real dens_total =0.0; real P_total =0.0; int nc = TP_N_COMPONENTS( p ); /* number of particle components */ cell_t c0 = RP_CELL(&(p->cCell)); /* cell and thread */ Thread *t0 = RP_THREAD( &(p->cCell) ); /* where the particle is in */ Material *gas_mix = THREAD_MATERIAL( t0 ); /* gas mixture material */ Material *cond_mix = p->injection->material;/* particle mixture material */ cphase_state_t *c = &(p->cphase); /* cell info of particle location */ real molwt[MAX_SPE_EQNS]; /* molecular weight of gas species */ real Tp = P_T(p); /* particle temperature */ real mp = P_MASS(p); /* particle mass */ real molwt_bulk = 0.; /* average molecular weight in bulk gas */ real Dp = DPM_DIAM_FROM_VOL( mp / P_RHO(p) ); /* particle diameter */ real Ap = DPM_AREA(Dp); /* particle surface */ real Pr = c->sHeat * c->mu / c->tCond; /* Prandtl number */ real Nu = 2.0 + 0.6 * sqrt( p->Re ) * pow( Pr, 1./3. ); /* Nusselt number */ real h = Nu * c->tCond / Dp; /* Heat transfer coefficient */ real dh_dt = h * ( c->temp - Tp ) * Ap; /* heat source term */ dydt[0] += dh_dt / ( mp * Cp ); dzdt->energy -= dh_dt; mixture_species_loop(gas_mix,sp,ns) { molwt[ns] = MATERIAL_PROP(sp,PROP_mwi); /* molecular weight of gas species */ molwt_bulk += C_YI(c0,t0,ns) / molwt[ns]; /* average molecular weight */ } /* prevent division by zero */ molwt_bulk = MAX(molwt_bulk,DPM_SMALL); for( ns = 0; ns < nc; ns++ ) { /* gas species index of vaporization */ int gas_index = TP_COMPONENT_INDEX_I(p,ns); if( gas_index >= 0 ) { /* condensed material */ Material * cond_c = MIXTURE_COMPONENT(cond_mix, ns ); /* vaporization temperature */ real vap_temp = MATERIAL_PROP(cond_c,PROP_vap_temp); /* diffusion coefficient */ real D = MATERIAL_PROP_POLYNOMIAL( cond_c, PROP_binary_diffusivity, c->temp); /* Schmidt number */ real Sc = c->mu / ( c->rho * D ); /* mass transfer coefficient */ real k = ( 2. + 0.6 * sqrt(p->Re) * pow( Sc, 1./3. ) ) * D / Dp; /* bulk gas concentration */ real cvap_bulk = c->pressure / UNIVERSAL_GAS_CONSTANT / c->temp * c->yi[gas_index] / molwt_bulk / solver_par.molWeight[gas_index]; /* vaporization rate */ real vap_rate = k * molwt[gas_index] * Ap * ( cvap_surf[ns] - cvap_bulk ); /* only condensation below vaporization temperature */ if( 0. < vap_rate && Tp < vap_temp ) vap_rate = 0.; dydt[1+ns] -= vap_rate; dzdt->species[gas_index] += vap_rate; /* dT/dt = dh/dt / (m Cp)*/ dydt[0] -= hvap[gas_index] * vap_rate / ( mp * Cp ); /* gas enthalpy source term */ dzdt->energy += hgas[gas_index] * vap_rate; P_total += cvap_surf[ns]; dens_total += cvap_surf[ns]*molwt[gas_index]; } } /*multicomponent boiling*/ P_total *= UNIVERSAL_GAS_CONSTANT * Tp; if (P_total > c->pressure && dydt[0] > 0.) { real h_boil = dydt[0] *mp *Cp; dydt[0] = 0.; for(ns=0; ns < nc; ns++) { int gas_index = TP_COMPONENT_INDEX_I(p,ns); if (gas_index >=0) { real boil_rate = h_boil / hvap[gas_index] * cvap_surf[ns] * molwt[gas_index] / dens_total; dydt[1+ns] -= boil_rate; dzdt->species[gas_index] += boil_rate; dzdt->energy += hgas[gas_index]*boil_rate; } } } } #include "udf.h" #define REMOVE_PARTICLES TRUE; DEFINE_DPM_LAW(Diam,p,ci) { P_CURRENT_LAW(p) = DPM_LAW_MULTICOMPONENT; { real dm = P_MASS0(p)-P_MASS(p); real rho = P_RHO(p); real vol = rho/dm; real mp = P_MASS(p); P_DIAM(p) = P_DIAM0(p) - DPM_DIAM_FROM_VOL(vol); if (mp <= 0 ) REMOVE_PARTICLES TRUE; } } |
May 13, 2016, 11:51 |
Rep Power: 18 |
Are you sure the UDFs are compiling correctly? If you're running R17.0 then you're missing an argument (the compressibility, Z); but this variable isn't present in the older versions (including Fluent 6.3).
The other obvious error (before checking your logic and code closely) is that you're defining REMOVE_PARTICLES as FALSE (and then TRUE) using pre-compiler directives. The UDF appears to compile but perhaps executing a line of TRUE TRUE is the cause of your unexpected results. If you're trying to replicate the example from the UDF manual for DEFINE_DPM_OUTPUT then use the MARK_PARTICLE macro as they have employed. Code:
MARK_PARTICLE(p, P_FL_REMOVED); |
May 20, 2016, 09:32 |
Simon
Hi 'e'
Thanks for your reply! I'm running Fluent 6.3 so the compressibility factor doesn't need to be specified. I don't get any error messages from the console when compiling the code. I tried removing the REMOVE_PARTICLES from the pre-compiler part, but the result is the same. I tried replacing the REMOVE_PARTICLES with the MARK_PARTICLE(...) code that you specified, but FLUENT doesn't recognize the macro. I get the error: Code:
..\..\src\particlediam_2.c(15) : error C2065: 'MARK_PARTICLE' : undeclared identifier |
May 20, 2016, 13:16 |
Saeid.doosty
Rep Power: 10 |
I have udf for initial you can help me
May 20, 2016, 17:58 |
Saeid.doosty
Rep Power: 10 |
Hiiii I am udf for initial can you help me
May 20, 2016, 18:37 |
#6 | |
Rep Power: 18 |
June 17, 2016, 22:14 |
Did you found a solution for your problem?
Are you now is the right range with the temperature and do you see change in particle diameter? |
Tutorial: Evaporating Spray Simulation | machineengine | Main CFD Forum | 0 | May 7, 2016 03:24 |
Transient Spray modeling of evaporating particles | sgov000ster | ANSYS | 0 | April 9, 2014 12:09 |
Euler-Euler simulation of evaporating spray | Xavier Ponticq | CFX | 0 | July 4, 2007 09:49 |
Multicomponent fuel spray and combustion | usker | Siemens | 0 | May 16, 2007 03:45 |
temperature fluctuations in an evaporating spray | kate | Main CFD Forum | 0 | June 20, 2006 07:35 |
