error: FLUENT received fatal signal (ACCESS_VIOLATION) |
May 3, 2016, 19:45 |
Rep Power: 10 |
I am quite new at UDFs, I’m trying to model the deposition of particles on a plate heat exchanger using four UDFs that are called by FLUENT at different times. The first UDF (impaction), called each time a particle impacts a deposition surface, determines the mass of the deposited particles and then calculate the thickness the mass gives the layer, this one is stored at the first UDM. The second UDF (heat flux), called during each fluent iteration, determines the heat flux through the deposit and base layers. The third UDF (injection initialization), called each time new particle streams are injected, and increments the simulation time before injecting a new set of particle streams. The fourth UDF (reset), called on-demand by the user, resets the user-defined memory locations (UDMLs), which store deposit information at each wall-face, to zero. The problem is when I hook the heat flux UDF, I got this error: Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () At first I thought that there would be some error in the UDF (heat flux) because apparently the denominator is zero (R_Eff) but then “ACCESS VIOLATION” means I’m trying to access some information that is not available yet. So I checked the first UDF (impaction) and I found that this one does not return any value.. when I open the UDM I got nothing, and I cannot find a way to solve it … Can anybody give me a clue?. Thanks in advance. Here is both of UDFs I used: //Particle impaction Boundary Condition UDF DEFINE_DPM_BC(capture_bounce_bc, p, thread, f, f_normal, dim) { real x[ND_ND],p_temperature,p_diameter; real A[ND_ND],area,flow,flux; real viscosity,visc_exponent; real p_rep_mass, deposit_mass; //Calculate the mass represented by the impacting particle p_diameter=P_DIAM(p); //Get Particle Diameter from Fluent p_rep_mass = P_FLOW_RATE(p)*TIMESTEP_SIZE; //p_rep_mass = P_MASS(p); printf("%1.9lf\t%1.9lf\n",p_diameter,p_rep_mass); //Determine viscosity of deposit particle p_temperature=P_T(p); //Get particle temperature from Fluent visc_exponent=14788/(p_temperature-T_Shift)-10.931; //Calculate deposit Viscosity viscosity=(p_temperature-T_Shift)*pow(10,visc_exponent); //Assume deposited mass is inversely proportional to viscosity when particle viscosity is less than critical deposit_mass=p_rep_mass; if(viscosity>critical_viscosity) { deposit_mass = p_rep_mass*critical_viscosity/viscosity; } //Calculate mass deposited per unit face area F_AREA(A,f,thread); area=NV_MAG(A); //Get face area from Fluent flux=deposit_mass/area; F_UDMI(f,thread,0)+=deposit_mass; printf("depôtt%lf\n",F_UDMI(f,thread,2)); F_UDMI(f,thread,2)+=flux/RHO_depôt; } //Heat flux boundary condition /*DEFINE_PROFILE(heat_flux_BC, thread, i) { real x[ND_ND]; real R_EFF, wall_temp; face_t f; begin_f_loop(f,thread) { //Calculate Effective thermal resistance of deposit layers R_EFF=R_BASE+F_UDMI(f,thread,2)/K_dep; F_UDMI(f,thread,1)=R_EFF; wall_temp=F_T(f,thread); //Get boundary temperature from Fluent F_PROFILE(f,thread,i)=(T_Cool-wall_temp)/R_EFF; } end_f_loop(f,thread) } |
May 3, 2016, 22:20 |
Rep Power: 18 |
Have you allocated at least three user-defined memory locations via User-Defined > User Defined > Memory... > Number of User-Defined Memory Locations?
May 4, 2016, 08:30 |
Rep Power: 10 |
May 4, 2016, 18:16 |
Rep Power: 18 |
You have an accent on the o in the variable RHO_depôt, perhaps this character isn't valid? Try reducing your code until you find the line responsible for your error.
May 5, 2016, 05:56 |
Rep Power: 27 |
The variable RHO_depôt is never defined, so I am surprised you did not have a compilation problem...
May 5, 2016, 13:23 |
Rep Power: 10 |
I tried what you said about RHO_depôt but i got the same error. Also, i have run my code without the second UDF for the Heat flux boundary condition, and i got this time no error but when i postprocess the results i got zero in all the UDMs (for the mass deposit and for the thickness) so i think that the problem is in the first UDF when i calculate the mass deposit maybe it doesn't work to get the particle Diameter from Fluent using P_DIAM(p); or the mass using P_MASS(p). But i can't figure out why or how should i make this thing work.
May 5, 2016, 13:27 |
Rep Power: 10 |
May 6, 2016, 03:55 |
Rep Power: 27 |
How did you conclude that your UDMs are all zeroes?
If you did it by looking at the output of "printf("depôtt%lf\n",F_UDMI(f,thread,2));", you might be misleading yourself, because the number is too small to show in this way, and you could better use "printf("depôtt%e\n",F_UDMI(f,thread,2)); ". Another way is to let Fluent plot the value of the UDMs on the surfaces you are interested in. Or let Fluent calculate the integral of the UDMs, or whatever. If you already did this, I have no other idea at this moment. |
May 7, 2016, 20:23 |
#9 | |
Rep Power: 10 |
Actually, i already let fluent plot the values of the UDMs on the surfaces i wanted however i get all the time zeroes...I got also, when i compile my code, a warning saying " 'capture_bounce_bc': not all control paths return a value " even if it is successfully compiling ... So, i think the problem is in the first UDF maybe in in the macros i'm using but i can't figure out what is exactly ... |
May 7, 2016, 20:39 |
#10 | |
Rep Power: 18 |
return PATH_END; |
May 7, 2016, 20:56 |
#11 |
Rep Power: 10 |
I tried what you said, this time i didn't get the warning but unfortunately i still get the same error which is " FLUENT received fatal signal (ACCESS_VIOLATION)" when i include the UDF of heat flux and i get zeroes in the UDMs when i exclude it.
May 8, 2016, 01:05 |
#12 | |
Rep Power: 18 |
You've also not defined T_Cool in the UDF provided. What is your complete UDF source file? |
May 8, 2016, 16:06 |
#13 | |
Rep Power: 10 |
The problem is in the UDMs, there is nothing stored in them, however i can't remove them because in some UDFs I’m using variables which are already calculated in the others and stored in the UDM so I’m using them, for example in the DEFINE_PROFILE of the heat flux boundary I’m using F_UDMI(f,thread,2) where the thickness of the deposit layer is calculated in the DEFINE_DPM_BC of the particles impaction Boundary Condition.... Something else, every time i run the code before i compile it, i allocate the UDMs I’m needing from Define >> User-Define >>Memory >> Number of user defined Memory locations. Am I wrong? I defined T_Cool, here is the complete UDF source code i'm using. Thank you for your help. Code:
//Global Variables Defined #include "udf.h" #include "models.h" #include "dpm.h" #define stdout #define stderr #define stdin #define T_Cool 300 // Cooling Temperature of the plate (K) #define T_depôt 320 // Temperature of the deposition (K) #define T_Shift 20 // Temperature Shift parameter for Browning Viscosity Model (K) #define K_dep 9.71 // Thermal Conductivity of deposit (W/m-K) #define RHO_depôt 3180 // Density of deposit particles (kg/m^3) #define TIMESTEP_SIZE 600 // Timestep Length (s) #define R_BASE 0.00034 // Thermal Resistance of Base Layer (m^2-K/W) #define RR_DBAR 10e-6 // Rosin-Rammler parameter for avg.particle size (m) #define RR_SF 1.243 // Rosin-Rammler parameter for shape factor #define RR_NUM_PARTICLES 1000 // Total Number of particle streams from injectors #define MASS_FLOW 50 // Total particle injected mass flow (kg/s) #define RR_DIAM_MAX 3e-3 // Rosin-Rammler maximum particle size (m) #define RR_DIAM_MIN 1e-7 // Rosin-Rammler minimum particle size (m) #define EXP 2.718282 // e #define PI 3.141593 // pi #define critical_viscosity 10000 // Critical viscosity for particle sticking (kg/m-s) /* UDM Locations 0 - Total Deposit Mass 1 - l/k Effective Thermal Re s 2 - thickness 3 - Current Simulation Time */ //Particle impaction Boundary Condition UDF that is called when particle 'p' impacts face 'f' DEFINE_DPM_BC(capture_bounce_bc, p, thread, f, f_normal, dim) { real p_loc[ND_ND],p_temperature,p_diameter; real plocy,pvel; real A[ND_ND],area,flow,flux; real viscosity,visc_exponent; real p_rep_mass, deposit_mass; //Calculate the mass represented by the impacting particle p_diameter=P_DIAM(p); //Get Particle Diameter from Fluent p_rep_mass = P_FLOW_RATE(p)*TIMESTEP_SIZE; printf("%1.9lf\t%1.9lf\n",p_diameter,p_rep_mass); //Determine viscosity of particles p_temperature=P_T(p); //Get particle temperature from Fluent visc_exponent=14788/(p_temperature-T_Shift)-10.931; //Calculate deposit Viscosity viscosity=(p_temperature-T_Shift)*pow(10,visc_exponent); // Finish Viscosity Calculation //Assume deposited mass is inversely proportional to viscosity when particle viscosity is less than critical deposit_mass=p_rep_mass; if(viscosity>critical_viscosity) { deposit_mass = p_rep_mass*critical_viscosity/viscosity; } //Calculate mass deposited per unit face area F_AREA(A,f,thread); area=NV_MAG(A); //Get face area from Fluent flux=deposit_mass/area; F_UDMI(f,thread,0)+=deposit_mass; //Add thickness to deposit layer if the face temperature is higher than T_depôt if(F_T(f,thread)>T_depôt) { printf("depôt\t%lf\n",F_UDMI(f,thread,3)); F_UDMI(f,thread,2)+=flux/RHO_depôt; return(PATH_ABORT); } return PATH_END; } //Heat flux boundary condition DEFINE_PROFILE(heat_flux_BC, thread, i) { real pos_vec[ND_ND]; real R_EFF, wall_temp; face_t f; begin_f_loop(f,thread) { //Calculate Effective thermal resistance of deposit layers R_EFF=R_BASE+F_UDMI(f,thread,2)/K_dep; F_UDMI(f,thread,1)=R_EFF; wall_temp=F_T(f,thread); //Get boundary temperature from Fluent F_PROFILE(f,thread,i)=(T_Cool-wall_temp)/R_EFF; printf("R_eff = %f\n", R_EFF); } end_f_loop(f,thread) } //Injection initialization UDF that defines the transition to a new simulation timestep, DEFINE_DPM_INJECTION_INIT(Injection_Init,I) { int i; real current_time=0; Thread*t; Domain*d; face_t f; d=Get_Domain(1); //Increment simulation time, print to screen and store a current simulation time at UDM No.3 thread_loop_f(t, d) { if (NNULLP(THREAD_STORAGE(t,SV_UDM_I))) { begin_f_loop(f,t) { F_UDMI(f,t,3)+=TIMESTEP_SIZE; printf("current_time = %f\n", F_UDMI(f,t,3)); } end_f_loop(f,t); } } } //Reset UDML to Zero - This is a "define on demand" UDF so it is executed by the user DEFINE_ON_DEMAND(Reset_UDMLs) { int i=0; Thread *t; Domain *d; face_t f; d = Get_Domain(1); thread_loop_f(t, d) { begin_f_loop(f,t) { for(i=0; i <4; i++) F_UDMI(f,t,i)=0; //Set UDM to zero } end_f_loop(f,t); } } |
May 8, 2016, 19:31 |
#14 |
Rep Power: 18 |
I've run your heat flux boundary condition in a simple case and found that the problem is with reading the face temperatures at time zero (with the F_T macro). The temperatures on faces are not defined when Fluent is started, and this DEFINE_PROFILE is called when the simulation is initialised. A simple fix would be to initially define the wall temperature as a fixed constant and then use F_T onward:
DEFINE_PROFILE(heat_flux_BC, thread, i) { real pos_vec[ND_ND]; real R_EFF, wall_temp; face_t f; begin_f_loop(f,thread) { //Calculate Effective thermal resistance of deposit layers R_EFF=R_BASE+F_UDMI(f,thread,2)/K_dep; F_UDMI(f,thread,1)=R_EFF; if (CURRENT_TIME > 0.) wall_temp=F_T(f,thread); //Get boundary temperature from Fluent else wall_temp=300.; // a default initial temperature F_PROFILE(f,thread,i)=(T_Cool-wall_temp)/R_EFF; printf("R_eff = %f\n", R_EFF); } end_f_loop(f,thread) } |
May 8, 2016, 19:50 |
#15 |
Rep Power: 10 |
I used the code you suggested but i still have the same error when running the complete code source. Did you run the complete one or just the heat flux boundary condition?
May 8, 2016, 19:59 |
#16 |
Rep Power: 18 |
I compiled the complete source code and hooked only the heat flux boundary condition. Try only running this define profile as that's where the source of the error was (you may need to restart Fluent after the segmentation error; not simply compile the UDF again).
May 8, 2016, 20:23 |
#17 |
Rep Power: 10 |
I did as you said but i still get the same error. Did you leave "R_EFF=R_BASE+F_UDMI(f,thread,2)/K_dep;" and only hook the heat flux UDF ? How could Fluent calculate R_EFF without hooking the first UDF where F_UDMI(f,thread,2) is calculated ?? Or Fluent gives a default value (zero) to this UDM so R_ EFF=R_BASE.
This time even if i remove F_UDMI(f,thread,2) i still have the same error i don't know why. Sorry for bothering you. |
May 8, 2016, 21:25 |
#18 |
Rep Power: 18 |
Yes, I compiled the entire code with my modified DEFINE_PROFILE as above and only hooked the heat flux boundary condition. Yes, the UDM values are defined as zero when allocated.
The error was with F_T and not the F_UDMI macro. Ensure you're updating the UDF correctly by following my compiling process for Fluent UDFs with an existing library loaded. |
May 11, 2016, 16:52 |
#19 | |
Rep Power: 10 |
[ImmersedBoundary] About the moving immersed boundary tutorial: icoDyMIbFoam+movingCylinderInChannelIco | wyldckat | OpenFOAM Community Contributions | 25 | September 14, 2021 18:15 |
fluentError: received a fatal signal (Segmentation fault). | thomaszhangjing | Fluent UDF and Scheme Programming | 11 | January 13, 2021 10:37 |
FLUENT received fatal signal (ACCESS_VIOLATION) | Mike Wong | FLUENT | 7 | October 17, 2014 14:17 |
FLUENT received fatal signal (ACCESS_VIOLATION) | osamaghani | FLUENT | 2 | March 31, 2012 17:15 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
