Heat source dependent on mass flow rate
Old   May 3, 2016, 14:02
Question Heat source dependent on mass flow rate
diegovda
User12 is on a distinguished road
I have some experience using fluent, but I am quite new at UDFs. I am trying to set a volumetric heat source which is dependent on the mass flow rate. I think I know how to implement a UDF for a volumetric heat source, but my problem begins when I want to calculate the mass flow rate in each centroid and use this value in the definition of the heat source.
Can anybody give me a clue?
Thank you very much!!
User12 is offline   Reply With Quote
Old   May 6, 2016, 04:24
pakk will become famous soon enough
With "mass flow rate" you mean density * velocity, right?
Do you have access to the Fluent manual? That gives info on how to access these variables in a UDF. (C_R(c,t) for density, and so on.)
Can you show how far you already got with the rest of the UDF? That gives a better idea on how much and what kind of help you need.
pakk is offline   Reply With Quote
Old   May 6, 2016, 07:32
diegovda
Thanks for the answer.
Yes, it would proportional to velocity and density, but I think that in the case of defining it this way, the cell area should also be included. I explain myself.
My need is to define a heat source, q (W/m3), which is proportional to the flow rate, m (kg/s). Then, the easiest way to define it would be:
q (W/m3)= C (J/kg) * m (kg/s) * 1/Vcell (1/m3)
C is a constant and Vcell is the cell volume.
However, the only way I know to read the mass flow rate is through F_FLUX(f,t), which is a face variable. When I use this parameter in the macro DEFINE_SOURCE, i get a segmentation fault error, which I think is due to that this macro only deals with cell variables (not face variables).
Then, I tried to define the mass flow rate using density, velocity and area.
q (W/m3)=C (J/kg) * v (m/s) * rho (kg/m3) * A (m2)
I am stuck on this point, since I have two problems. 1) I don't know how to define the area. I think this would be again a face variable. 2) I can't see which is the area I need. I mean, which is the area that defines the amount of fluid inside the cell? Is it the area of a specific face? Is it the area normal to the velocity vector?
Here I paste the UDF I have been writing.
#include "udf.h"
#include "mem.h"
real U;
real V;
real VEL;
real RHO;
DEFINE_SOURCE(heat_source,thread,dS,eqn)
real source;
cell_t c;
Thread *t;
U=pow(C_U(c,t),2);
V=pow(C_V(c,t),2);
VEL=pow(U+V,0.5);
RHO=C_R(c,t);
source=20000*VEL*RHO*...; AREA IS MISSING
return source;
20000 is an arbitrary value for C. VEL is velocity magnitude, calculated through the squared radial and axial velocity components (axisymmetric simulation).
Regards
Old   May 6, 2016, 08:22
From a physical point of view, I don't understand this. Flow rate is always through some surface, and heat source is local. I think there you already have your 'missing surface'.
Suppose in your model the flow rate would be 1 kg/s, and the corresponding heat source would be 1 W/m3. If you then would look at half of your model (such that it splits the flow 50/50), the flow rate would be 0.5 kg/s, so the heat source in that half model would be 0.5 W/m3, but that does not make any sense: the heat generation per unit volume should not depend on how big the volume is you are looking at.
I don't know what you need to do, so I don't know what to change it to. Below are two options that make sense from a physical point of view, but that does not mean they describe your situation.
  • Total heat generated (W) can be proportional to the total mass in the system (kg). Then the heat source (W/m3) is proportional to the density (kg/m3).
  • Total heat generated (W) can be proportional to the magnitude of the linear momentum of your fluid (kg m/s). Then the heat source (W/m3) is proportional to density multiplied by the magnitude of the velocity (kg/m2.s).
Old   May 9, 2016, 05:15
diegovda
Thanks again for answering.
From your reasoning I could change my point of view and use a different approach for my problem.
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 08:55
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Target mass flow rate Saturn FLUENT 0 December 10, 2004 05:18
