problem with coupling UDFs
Old   April 26, 2016, 06:32
Default problem with coupling UDFs
Hamidreza
hamidreza118 is on a distinguished road
I wrote a UDF and it is compiled and loaded without any error, but there seems to be a deficiency as it is not ending in the result i'm expecting.
I have a DEFINE_PROFILE macro with a begin and end loop and there's another UDF called "void transformation (Thread *f_thread)" which i introduced in my udf to store some vectors in F_UDMI. but my problem is that i can not couple these UDFs when i'm compiling. I think i need something like if (RP_Get_Integer (...)) transformation (f_thread) in the first udf but i have no idea how to trigger the coupling as i'm inexperienced in this subject.
Thanks in Advance.
hamidreza118 is offline   Reply With Quote
Old   April 26, 2016, 07:30
Bruno Machado
Bruno Machado is on a distinguished road
Thanks in Advance.
can you post your UDF or the void transformation (Thread *f_thread) so we can see it and try to come with a solution?
Bruno Machado is offline   Reply With Quote
Old   April 26, 2016, 08:29
Hamidreza
I've already done that but as i previously mentioned the links between DEFINE_PROFILE and void is not there! I see somewhere used the if(RP_Integer ... ) to trigger the link, so my code looks like this now:
DEFINE_PROFILE(HF,f_thread,index)
/*declaring all variables*/
if (RP_Get_Integer(“needing_transformation")==1) transformation (f_thread)
void transformation(Thread *f_thread)
but when i'm trying to compile this Fluent says:
there is a missing ';' before '{' in my if line !!
but i'm sure after if we shouldn't use semi colon, should we??
and I'm very sorry but do you have any idea how should i assign "needing_transformation" a value like 1 to link these two, since i don't know what RP_Integer.. really does although i've read a lot about it..
Thank you so so so much
rp_get_integer, udfs coupling, void
Problem in using system coupling in ANSYS 14.5 yhy20081016 FLUENT 1 April 16, 2016 08:39
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 18:18
UDFs' problem Benny FLUENT 14 June 13, 2005 12:05
Fluid-structure coupling problem bluebird Main CFD Forum 4 January 25, 2003 11:04
Fluid-structure coupling problem bluebird CFX 1 January 17, 2003 06:46
