2D UDF for inlet y velocity
Old   April 25, 2016, 19:45
Default 2D UDF for inlet y velocity
Keyu Dhingani
Keyu is on a distinguished road
I have seen and used UDFs for the inlet x velocity, but what do I do to make a UDF for inlet y velocity.
Here is the UDF that I used for inlet x velocity.
#include "udf.h"
#define umean 10.0
#define R 0.0005
DEFINE_PROFILE(inlet-x-velocity,t,i)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y = x[1];
F_PROFILE(f,t,i) = (3./2.)*umean*(1-pow((y-R)/R,2));
end_f_loop(f,t)
I tried replacing x with y and vice versa to hopefully get the y-direction velocity, but unsuccessful.
Any suggestions here will be useful.
Thanks,
Keyu
Keyu is offline   Reply With Quote
Old   April 26, 2016, 06:01
Bruno Machado
Bruno Machado is on a distinguished road
This line varies the position along the X, Y, Z axis (0,1,2 respectively).
y = x[1];
If you want a velocity profile normal to the Y direction, you need to use the variation of the position in the X direction if 2D and X and/or Z direction if 3D.
ps: you asked in a topic and created another one with exactly the same question. there is no need to do that.
Bruno Machado is offline   Reply With Quote
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 07:45
Having trouble adapting serial UDF to work in parallel muyuntao Fluent UDF and Scheme Programming 1 November 10, 2015 14:42
Velocity boundary condtion UDF help victoryv Fluent UDF and Scheme Programming 2 October 9, 2012 16:27
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 13:20
