how to calculate Tmean over the entrance length in a pipe?
Old   April 23, 2016, 21:15
Default how to calculate Tmean over the entrance length in a pipe?
sharmann2 is on a distinguished road
Hey, I want to calculate Tmean over the entrance length in a pipe, in fluent.
I guess UDF is the only way to do it.
Is there some PDF or material, which can help me understand how to make UDF for mean temp
sharmann2 is offline   Reply With Quote
Old   April 24, 2016, 18:17
Bruno Machado
Bruno Machado is on a distinguished road
You can go to report > surface integral and integrate the temperature at the surface you want.
Bruno Machado is offline   Reply With Quote
Old   April 25, 2016, 00:52
François Grégoire
macfly is on a distinguished road
Example 1 shows how you can integrate a variable: https://www.sharcnet.ca/Software/Flu...udf/node20.htm
The simplest way would be to create a fluid zone in the mesh that corresponds to the entrance length of the pipe, then you just have to loop over this zone.
macfly is offline   Reply With Quote
Old   June 25, 2016, 02:52
Williams
gearman is on a distinguished road
Dear macfly!
Why we can't surface integral and integrate the temperature at the surface we want as Bruno Machado said? why we must use the udf?Thank you very much!
gearman is offline   Reply With Quote
Old   June 26, 2016, 11:20
François Grégoire
Yes gearman, you can postprocess surface or volume integrals as Bruno explained, but you got to use UDFs if you want to calculate and use integrals during solving.
Old   June 27, 2016, 07:19
Williams
how to calculate the viscous dissipation rate for a turbulent pipe flow Yakamoz Main CFD Forum 1 June 16, 2012 14:35
Turbulence length scale in pipe flow lei Main CFD Forum 0 September 26, 2002 05:07
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
