function "CX_Message0" not found
Old   April 22, 2016, 13:59
Default function "CX_Message0" not found
François Grégoire
macfly is on a distinguished road
Hi, I'm trying to display only one message with Message0 but I always get the following error message: function "CX_Message0" not found. I get the same error whether I interpret or compile the udf.
macfly is offline   Reply With Quote
Old   April 22, 2016, 17:25
Bruno Machado
Bruno Machado is on a distinguished road
Never came across this Message0 macro. what it does?
if you want to print the message only 1 message, you can add a if condition that matches your cell condition like the one above
if ((c%10000)==0)
Message("");
Bruno Machado is offline   Reply With Quote
Old   April 22, 2016, 20:21
`e`
`e` is on a distinguished road
Message0 is a modification of Message which only executes on compute node-0 (and also runs in serial). For printing a message only once per compute node, you could use a flag which switches off after the first message is printed (see a similar example here).
What is your full source code of the user-defined function?
`e` is offline   Reply With Quote
Old   April 24, 2016, 23:32
François Grégoire
Thanks for the suggestions e and Bruno. My udf is very simple. In the end restarting Fluent did the trick, Message0 works, I don't know what was wrong before.
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 11:45
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
