April 21, 2016, 23:29 |
writing ADJUST macro for Parallel FLUENT
Peter Aestas
Rep Power: 13 |
hi friends,
i am trying to writing an ADJUST macro for Parallel FLUENT for a transient case. Part of the function of My ADJUST is to get the temperature in a certain point at every time step, and the UDF is based on the example in UDF manual. But when i ran the program, it works quite slow. My guess is that, in every timestep, the ADJUST marco will loop at every single iterations. I am trying to figure out a way, let this part of ADJUST only loop one time in a sing timestep, but i have not found yet. Does anyone have a good idea? Code:
DEFINE_ADJUST(my_adjust, d) { #if !RP_HOST Domain *domain=Get_Domain(1); Thread *thread,*thread_1; face_t f; Thread *t,*t0,*t1; cell_t c,c0,c1; real x[ND_ND]; real thermal_con; #else int i; int yushu; real CENTROID_T; real melt_depth; real solid_x,liquid_x; #endif #if !RP_NODE FILE *fp = NULL,*fp1 = NULL; char filename[]="test.txt"; char filename1[]="test1.txt"; #endif #if PARALLEL int size; /* data passing variables */ real *array; real *x_array; real *y_array; real *fraction_array; real xx[ND_ND]; int pe; #endif /* Only Serial and Compute Nodes have data on threads */ #if !RP_HOST thread=Lookup_Thread(domain,WALLID); #endif #if !RP_NODE /* SERIAL or HOST */ if ((fp = fopen(filename, "a"))==NULL) Message("\n Warning: Unable to open %s for writing\n",filename); else Message("\nWriting Pressure to %s...",filename); #endif /* UDF Now does 3 different things depending on SERIAL, NODE or HOST */ // #if !PARALLEL /* SERIAL */ // begin_f_loop(f,thread) // fprintf(fp, "%g\n", F_T(f,thread));/* Simply write out pressure data */ // end_f_loop(f,thread) // #endif /* !PARALLEL */ #if RP_NODE /* Each Node loads up its data passing array */ size=THREAD_N_ELEMENTS_INT(thread); array = (real *)malloc(size * sizeof(real)); x_array = (real *)malloc(size * sizeof(real)); y_array = (real *)malloc(size * sizeof(real)); if(temp_time!=CURRENT_TIME) { begin_f_loop_int(f,thread) { array[f]= F_T(f,thread); F_CENTROID(xx,f,thread); x_array[f]=xx[0]; y_array[f]=xx[1]; } } end_f_loop_int(f,thread) /* Set pe to destination node */ /* If on node_0 send data to host */ /* Else send to node_0 because */ /* compute nodes connect to node_0 & node_0 to host */ pe = (I_AM_NODE_ZERO_P) ? node_host : node_zero; PRF_CSEND_INT(pe, &size, 1, myid); PRF_CSEND_REAL(pe, array, size, myid); PRF_CSEND_REAL(pe, x_array, size, myid); PRF_CSEND_REAL(pe, y_array, size, myid); free(array); free(x_array); free(y_array);/* free array on nodes once data sent */ /* node_0 now collect data sent by other compute nodes */ /* and sends it straight on to the host */ if (I_AM_NODE_ZERO_P) compute_node_loop_not_zero (pe) { PRF_CRECV_INT(pe, &size, 1, pe); array = (real *)malloc(size * sizeof(real)); x_array=(real *)malloc(size * sizeof(real)); y_array=(real *)malloc(size * sizeof(real)); PRF_CRECV_REAL(pe, array, size, pe); PRF_CRECV_REAL(pe, x_array, size, pe); PRF_CRECV_REAL(pe, y_array, size, pe); PRF_CSEND_INT(node_host, &size, 1, myid); PRF_CSEND_REAL(node_host, array, size, myid); PRF_CSEND_REAL(node_host, x_array, size, myid); PRF_CSEND_REAL(node_host, y_array, size, myid); free((char *)array); free((char *)x_array); free((char *)y_array); } #endif /* RP_NODE */ #if RP_HOST CENTROID_T=0.0; compute_node_loop (pe) /* only acts as a counter in this loop */ { /* Receive data sent by each node and write it out to the file */ PRF_CRECV_INT(node_zero, &size, 1, node_zero); array = (real *)malloc(size * sizeof(real)); x_array=(real *)malloc(size * sizeof(real)); y_array=(real *)malloc(size * sizeof(real)); PRF_CRECV_REAL(node_zero, array, size, node_zero); PRF_CRECV_REAL(node_zero, x_array, size, node_zero); PRF_CRECV_REAL(node_zero, y_array, size, node_zero); // for (i=0; i<size; i++) // // fprintf(fp, "current time=%lf, x=%lf,y=%lf, temperature=%lf\n",CURRENT_TIME*1e3, x_array[i],y_array[i],array[i]); if(temp_time!=CURRENT_TIME) { for (i=0; i<size; i++) { if(x_array[i]<0.6*0.005e-3&&y_array[i]>hr/2*h&&y_array[i]<(0.6+hr/2)*h) { CENTROID_T=array[i]; break; } } } free(array); free(x_array); free(y_array); } if(temp_time!=CURRENT_TIME) { temp_time=CURRENT_TIME; fprintf(fp, "current time=%lf, temperature=%lf\n",CURRENT_TIME*1.0e3, CENTROID_T); } #endif /* RP_HOST */ #if !RP_NODE /* SERIAL or HOST */ fclose(fp); /* Close the file that was only opened if on SERIAL or HOST */ Message("Done\n"); #endif } |
April 22, 2016, 00:52 |
Rep Power: 18 |
Use the first_iteration variable (inbuilt within Fluent; don't initialise or declare this variable):
if (first_iteration) { // code only executed at the first iteration of a time step } |
April 22, 2016, 03:12 |
#3 | |
Peter Aestas
Rep Power: 13 |
Thanks so much! i find the first_iteration variable in UDF manual, and i have solved this problem by using this!
April 22, 2016, 03:24 |
#4 | |
Rep Power: 17 |
USE DEFINE_EXECUTE_AT_END instead. It will be executed once at each time step end.
April 22, 2016, 03:44 |
Peter Aestas
Rep Power: 13 |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 09:08 |
How to Mix AIR and WATER | Elvis1991 | FLUENT | 12 | December 1, 2016 13:28 |
writing the values of particles in fluent | krishna.n | Fluent Multiphase | 0 | April 18, 2016 02:57 |
what is the syntax for writing inverse hyperbolic functions in UDFs ANSYS FLUENT | murthya3 | Fluent UDF and Scheme Programming | 9 | March 2, 2016 16:35 |
HELP! Fluent macro definition | hamish888 | FLUENT | 1 | November 1, 2010 07:12 |
