enum
Old   April 18, 2016, 01:05
Default enum
hwet is on a distinguished road
Hi All
Particle stripping from the wall film in fluent can be modeled with the foucart, orourke or friedrich models which are builtin and select-able from the GUI. Each calculates the diameter of the particle stripping from the film and injects it as discrete phase.
Has someone ever used a user separation law? I have experimental data on which I want to base my separation rather than using the above models.
This is from the file sg_film.h
enum
  SEPARATION_FOUCART = 0,
  SEPARATION_OROURKE,   /* O'Rourke & Amsden, SAE 961961 */
  SEPARATION_FRIEDRICH, /* Friedrich ASME May 2008 Vol 051301-1. */
  SEPARATION_USER
Does someone know how enum works and what it is? Where will the output from my UDF go to for the separation model? I am suspecting I have to use SEPARATION_USER somehow?
hwet is offline   Reply With Quote
Old   April 18, 2016, 19:18
`e`
`e` is on a distinguished road
enum simply enumerates the variables as integers, for example in your code an equivalent segment could be:
int SEPARATION_FOUCART = 0;
int SEPARATION_OROURKE = 1;
int SEPARATION_FRIEDRICH = 2;
int SEPARATION_USER = 3;
Note that the last variable SEPARATION_USER is essentially a count of the number of variables.
`e` is offline   Reply With Quote
Old   April 18, 2016, 20:18
OK,so why is it even provided in the header file?
I fail to understand the starting point of a wall film UDF. There are no examples in the UDF manual, and there has to be a way to not use the standard fluent separation models for the wall film separation and use a UDF instead?
Nowhere to hook a wall film UDF either in the GUI...
Old   April 19, 2016, 22:07
`e`
Fluent is closed source, therefore we can't see the source files to determine where or why these variables are enumerated. I'm not familiar with the wall film models, perhaps you could achieve a similar model using different hooks/UDFs.
Old   April 19, 2016, 23:32
Thanks for that. I read on Ansys 17 upgrades that the exact same model I want ed to put in as a UDF for wall film has been included and a new tab in GUI to hook such UDF's is shown in the manual screenshot representing Fluent 17.
But that tab is not actually available in Fluent 17
Old   April 20, 2016, 19:14
`e`
Perhaps another model or option needs to be first enabled before the wall film model is shown? They occasionally move options around but if you're reading the current version of the manual then it should be accurate.
what's mean enum in udf zhu FLUENT 3 May 6, 2024 04:24
[OpenFOAM] failed to load vboxvideo gux290 ParaView 12 April 4, 2015 09:32
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
