how to plot or to make a contour of P_USER_REAL? |
April 4, 2016, 04:48 |
#1 | |
Sangwoo Kim
Rep Power: 12 |
Hi all.
I'm writing a code for situation of particle impact on the wall. When a particle hit the wall, if some criterion is satisfied, then particle is trapped and if not, then particle is reflected. I want to know the mass flux of trapped particles on the wall. So the code is written in this way: Quote:
Here, the flow field converged well. That is, residual and other monitors converge to a constant, and DPM concentration at outlet also converges. So I expected that C_UDMI(c0,t0,0) will also converge to a constant, because it is mass flux trapped at the wall and steady state solution is obtained. But C_UDMI keeps increasing with nearly constant slope.. It looks like that C_UDMI is accumulated with the value of C_UDMI at the previous iteration! Am I understanding right? And how can I fix this problem?? I am not good at UDF actually, so any fundamental advice will also be helpful to me. Second question is about P_USER_REAL(p,0). I heard that I should use P_USER_REAL(p,0) for storing particle-related value when I use parallel solver. Here, how can I see P_USER_REAL? For example, I expect that the value of mass flux will be stored in P_USER_REAL, so I may be able to make a contour of P_USER_REAL so that I can show where particles are trapped more. But there is no option about it in Results > Graphics > Contours > Contours of.. Any comment will be very helpful to me. Thank you.
Best regards |
[swak4Foam] Foam warnings - related to swak4Foam | Salam-H | OpenFOAM Community Contributions | 20 | August 2, 2015 16:40 |
plot contour on a plane | 1988 | FLUENT | 9 | August 14, 2014 07:03 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 12:51 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
contour plot of stream function | liu | FLUENT | 6 | August 19, 2003 23:30 |
