Interpreting UDF on multiple HPC nodes!
Old   March 19, 2016, 21:18
Default Interpreting UDF on multiple HPC nodes!
supermanks is on a distinguished road
Hello folks,
I have been running a dynamic mesh case along with an interpreted UDF on my windows machine and recently shifted some larger cases to a HPC cluster.
The cases work fine when I'm using 1 node (16 processors), and the UDF interprets perfectly. However, when I try to scale my setup with 2 nodes, I encounter the infamous "syntax error: line 1" message where "line 1" corresponds to the header directive, "#include "udf.h"".
I've spent almost the whole day looking at other users' posts here and tried all possible fixes (for eg. the "dos2unix" command), but I'm not totally sure why the UDF would interpret on 16 processors, but throw out an error while I expand to 32 processors (2 nodes). (I assure you my UDF is a very simple inlet condition, and almost similar to the one in the fluent UDF manual.)
Any quick ideas or help would be greatly appreciated, thank you!
Regards
supermanks is offline   Reply With Quote
Old   March 21, 2016, 13:51
Any ideas, anyone?
Error during interpreting UDF for VoF vekh Fluent UDF and Scheme Programming 9 March 12, 2018 02:57
parse error while interpreting udf chem engineer Fluent UDF and Scheme Programming 10 September 18, 2015 10:06
MPI code on multiple nodes, scalability and best practice t.teschner Hardware 0 October 7, 2014 06:07
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
UDF for looping over nodes in cells. Malcolm Wallace FLUENT 3 July 3, 2000 10:22
