access interior face parameters
Old   March 18, 2016, 11:51
gewuzhizhi is on a distinguished road
hello everyone, i'm now wrting a udf to access some flow parameters on an interior face,such as pressure and velocity,etc. during each iteration. However, the document provided by fluent says that the face macro (F_P,F_U,etc) can not be used on interior face, so do you have any ideas to visit the parameters? or can i read the adjacent cell's value?
the solver is density based ns equation solver
Last edited by wyldckat; March 19, 2016 at 18:26. Reason: merged posts that were a few minutes apart
gewuzhizhi is offline   Reply With Quote
Old   March 19, 2016, 19:56
`e`
`e` is on a distinguished road
Fluent is a finite volume method solver and therefore the velocity and pressures are calculated for each cell (at their centres). Nodal values are interpolated. Why not use the cell centroid values (C_U etc) instead, what do you want your UDF to achieve?
`e` is offline   Reply With Quote
Old   March 21, 2016, 07:52
thanks for your reply. actually I am try to access the interior face values to revise the coresponding parameter on the inlet. Now, I have a new idea that is to read the adjacent cell of the interior face. there are some macros to achieve this goal.
Old   January 5, 2018, 09:07
Default UDF code to measure the Velocity and pressure interior face.
Prabhu R
Prabhumsrit is on a distinguished road
Can u please send any UDF code to measure the Velocity and pressure interior face.
Prabhumsrit is offline   Reply With Quote
Old   January 5, 2018, 09:12
Default velocity and pressure on interior face
Prabhu R
I want to measure the velocity and pressure on interior face in Nozzle design and also required further thrust calculation. Please share any details with u and it is useful for my project and
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Is there a way to access the gradient limiter in Fluent ? CFDYourself FLUENT 1 February 16, 2016 06:49
Parameters rhoSimpleFoam marcus85 OpenFOAM Pre-Processing 0 May 15, 2013 10:36
Parameters for multigrid solver HaZe OpenFOAM Running, Solving & CFD 3 January 28, 2012 03:05
