udf for volume fraction and temperature
Old   March 15, 2016, 04:16
Smile udf for volume fraction and temperature
YUPeng
YUPeng is on a distinguished road
Hello
I want an UDF that computes volume fraction and temperature of one phase(the primary phase or the second phase) in two phase flow at each cell as fluid flows in order to calculate a coefficient to adjust the calculation at the end of iteration.Part of the code is shown as follows.It compiles well,but when I exectue it for the calculation,the error(received a fatal signal(Segmentation fault)) occours.
I would be appreciated if you could help me on this
Thankyou very much
Part of the code is shown as follows:
DEFINE_EXECUTE_AT_END(d_sum)
real d;
real d_sum=0;
cell_t cell;
Thread **pt;
Thread *cell_threads;
Domain *mixture_domain;
mixture_domain=Get_Domain(1);
mp_thread_loop_c(cell_threads,mixture_domain,pt)
begin_c_loop(cell,pt[0])
d=C_VOF(cell,pt[0])*C_R(cell,pt[0]);
d_sum+=d;
C_UDMI(cell,pt[0],0)=d_sum;
end_c_loop(cell,pt[0])
printf("sum:%g\n",d_sum);
YUPeng is offline   Reply With Quote
Old   March 16, 2016, 16:21
`e`
`e` is on a distinguished road
You're using user-defined memory (with C_UDMI to store 'd_sum'), have you allocated memory by enabling at least one memory locations (Define > User-Defined > Memory...)?
`e` is offline   Reply With Quote
Old   March 16, 2016, 21:43
Smile
YUPeng
Thank you for your reply,the user-defined memory has been allocated,but once I used C_VOF() in DEFINE_EXECUTE_AT_END(d_sum) to computes volume fraction, the error(received a fatal signal(Segmentation fault)) occoured.So I calculate it in the Source term, and the code runs well. I have read the POST(http://www.cfd-online.com/Forums/flu...-fraction.html), the code which is similar to mine can run well.Now Iwant to know what went wrong,please give me some advice.
udf c_vof
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
UDF for mass fraction (spilled organic liquid) Klemens Schatka FLUENT 4 July 28, 2009 02:27
