Error while opening fluent using cmd prompt
Old   March 14, 2016, 07:08
Default Error while opening fluent using cmd prompt
SAM S is on a distinguished road
Hi, to compile a source term udf I installed VC++ 2015 and from forum's advice included environment variables. Now when I launch fluent using cmd, I am getting the following error
Error: sopenoutputfile: unable to open file for output
Error Object: "C:\Program Files (x86)\Microsoft Visual Studio 14.0\cleanup-fluent-HP-3964.bat"
When I try to build and load the udf ignoring the above error I am getting
Error: The UDF library you are trying to load (libudf) is not compiled for 2ddp on the current platform (win64).
The system cannot find the file specified.
E:\project 1\libudf\win64\2ddp\libudf.dll
Can anyone figure out where I am going wrong?
Thank you
SAM S is offline   Reply With Quote
Old   March 14, 2016, 09:36
pakk will become famous soon enough
I see that you have spaces in your folder names. This sometimes gives problems. (I don't know if they cause these specific problems...)
pakk is offline   Reply With Quote
Old   March 15, 2016, 02:26
Thank you pakk for your reply.
But I didnt save any fluent related files with space inbetween. Is there any other solution. One more query, what should be the path variables given under environmental variables. Whether it should be given in user variables or system variables.
I am in need of urgent help.
Thank you.
Old   March 15, 2016, 04:23
Your first message indicates otherwise:
E:\project 1\...
That empty thing between the "t" and the "1" is a space, and it is the folder name in which your simulation is, so all fluent related files are probably there...
Old   March 15, 2016, 04:38
I am sorry I didnt notice that. I tried compiling after removing that space but still same problem persists. I am seeing other ways to rectify it. If anyone solved it before please let me know your experience
Old   June 24, 2016, 04:51
Saumik Kumar Dey
SKDinfinity is on a distinguished road
Hi!
My problem is worst. I couldn't even open fluent from a normal command prompt.
whenever I write "fluent 2ddp" enter ... It is showing 'fluent' is not recognized as an internal or external commands.
Please help if u have time.
Thanks, SKD
SKDinfinity is offline   Reply With Quote
Old   June 24, 2016, 05:12
You need to have Fluent installed on your computer before you can work with it.
Old   July 2, 2016, 09:51
Saumik Kumar Dey
Hi Pakk !
I do have Fluent installed in my system but may not be correctly. When I run from start menu by clicking Fluent 14.0 application it runs fine, but it don't open from the command prompt.
[ICEM] opening fluent .cas file in ICEM Will Anderson ANSYS Meshing & Geometry 12 May 13, 2013 02:49
problem opening a cfx definition file with fluent samaras387tasos ANSYS 0 February 18, 2011 16:28
Opening a .jou file in FLUENT Martin_D FLUENT 5 October 12, 2010 11:15
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
