higher temperature in the simulation
Old   March 10, 2016, 06:48
Default higher temperature in the simulation
Ganesh K C
kcgmech is on a distinguished road
I try to simulate tig welding in fluent. when i do the simulation using 2D model, the induced temperature on top surface reached close to 4500K. but it is not the realistic value compared to published article. i took material property of 304 stainless steel, current 200A, voltage 14. how to trouble shoot this ? published articles reported the peak temperature of 2500K max. melting point is 1723K.
K.C.Ganesh
Research Scholar
NIT Trichy
India
kcgmech is offline   Reply With Quote
Old   March 10, 2016, 07:11
pakk will become famous soon enough
Try to find the reason for the difference.
Think about what could cause a difference. Think about what you can check. Eliminate things. Find out more. Do research...
If you are a research scholar, then surely you must have done some investigation before in your career? This does not sound like a Fluent question, but more like a "how should I do my job" question...
pakk is offline   Reply With Quote
Divergence error temperature - engine simulation andrewpm1993 FLUENT 0 March 4, 2015 18:03
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
static temperature is higher than total temp. in buoyancy problem amirbahador FLUENT 2 October 24, 2010 08:21
need suggestion on temperature simulation Bin Li CFX 4 June 23, 2000 03:35
