March 8, 2016, 02:54 |
UDF for free and forced vibration cylinder
N B Khan
Rep Power: 12 |
Dear Friends,
Need your help in making code to analyze vortex induced vibration for forced vibration cylinder and free oscillating cylinder in Fluent. I am beginner in field of UDF and facing a lot of problem. Plz help Currently, I successfuly simulated once 2D case study using the following UDF. DEFINE_CG_MOTION(osc,dt,vel,omega,time,dtime) { Thread *t; Domain *d = Get_Domain(1); real x_cg[3], force[3], moment[3]; real accl, dv; real mass = 0.2; real wn = 12.0; real k= mass * wn*wn; real c = 2*mass*wn*0.00; int i; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); t = DT_THREAD(dt); for(i=0;i<3;i++) x_cg[i]=DT_CG(dt)[i]; Compute_Force_And_Moment(d, t, x_cg, force, moment, TRUE); force[1] += -k*x_cg[1] - c*vel[1]; I used this UDF and its working. ....In this UDF, it is seem free osciallation ( I think).. I have 2 very basic question. 1. How to change the above UDF into force oscillation with A=0.3D , A=amplitude and D is Dia of cylinder. In addition, the motion of cylinder is sinusoidal i.e. y(t) =ASin(2*3.14*f*t), and y=crossflow direction, A=amplitude and f=Oscillating frequency of cylinder..........So where should I adjust or add the equation in UDF 2. Reduced Velocity,Ur=U/(fn*D). If I want to perform analysis at Ur=2, Ur=4 and Ur=8. To perform analysis at different Ur, what parameter is required to be modify. All the analysis will be at Re=10,000. Thanks in advance Regards Niaz |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Bubble dynamic under forced vibration | arsalan.dryi | OpenFOAM Running, Solving & CFD | 1 | July 9, 2015 15:09 |
forced convection on a cylinder | mountaineer | OpenFOAM | 3 | September 27, 2011 10:30 |
Request for UDF code for forced vibrations | jagadeesh putta | Main CFD Forum | 0 | November 21, 2007 21:46 |
Request for UDF code for forced vibrations | jagadeesh putta | FLUENT | 0 | November 21, 2007 21:43 |
