Error: receive a fatal signal(Segmentation fault)
Old   March 6, 2016, 04:23
Question Error: receive a fatal signal(Segmentation fault)
Nate Lau
SNeCu is on a distinguished road
I wirte UDF to get momentum flux in x direction on a face after each iteration. However, it shows error: receive a fatal signal(Segmentation fault). Error Object: #f and it cannot continue. Could any one tell me where is the mistake(k-e, series)? Thanks.
#include "udf.h"
DEFINE_EXECUTE_AT_END(momentumxflux)
real mf=0;
Domain *d;
Thread *t;
face_t f;
thread_loop_f(t,d)
begin_f_loop(f,t)
mf+=F_FLUX(f,t)*F_U(f,t);
end_f_loop(f,t)
printf("Momentum flux on this face is: %g\n", mf);
SNeCu is offline   Reply With Quote
Old   March 6, 2016, 15:57
Bruno Machado
Bruno Machado is on a distinguished road
#include "udf.h"
real mf=0;
Domain *d;
Thread *t;
face_t f;
thread_loop_f(t,d)
begin_f_loop(f,t)
end_f_loop(f,t)
Since you are not hooking it in any boundary, I think you gotta define the value of the thread. Have a look in your case file and change your code in order to match this new face thread value.
Bruno Machado is offline   Reply With Quote
Old   March 7, 2016, 08:33
pakk will become famous soon enough
Yes. This.
Two relevant lines from the code:
Domain *d;
The line above means: reserve variable "d" to contain a pointer a domain.
thread_loop_f(t,d)
This means: loop through all threads in domain "d". But what is domain "d"? You didn't specify it yet! This is causing your program to crash.
And actually, you don't want to loop through all threads. You want to have only one thread: the face that you are interested in. You need to find a way to specify this face, look in the help for this.
pakk is offline   Reply With Quote
Old   March 15, 2016, 23:16
Nate Lau
Yes, I revised the code and it works! Thank you.
fluent - udf, fluent 14 to fluent 15., momentum, segmentation fault, udf and programming
fluentError: received a fatal signal (Segmentation fault). thomaszhangjing Fluent UDF and Scheme Programming 11 January 13, 2021 10:37
a fatal signal (segmentation fault) Turbo_hrf Fluent UDF and Scheme Programming 4 September 14, 2017 10:35
Fluent error: Fatal error (Segmentation fault) shufang FLUENT 2 April 20, 2015 08:06
receive fluent received a fatal signal (Segmentation fault). chenkaiqe FLUENT 2 March 10, 2015 09:21
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
