which macros should I use in udf?
Old   March 4, 2016, 10:13
Default which macros should I use in udf?
志新高(Zhixin Gao)
zhixin is on a distinguished road
Hi all,
I'm doing some simulation using species transport model(no reaction) and k-e model, and I need to calculate some variation using udf. Here is the formula I used: the mass fraction of o2 in the cell near the wall(mass_frac) to divide the distance of the centroid of the first layer (dist). Here is the part I plan to use to calculate in fluent.
real CR;
real dist;
real mass_frac;
cell_t c;
thread_loop_c(t,d)
if(THREAD_ID(t)==36)//elbow ID
begin_c_loop(c,t)
mass_frac=C_YI(c,t,0);//mass fraction of o2
dist=C_WALL_DIST(c,t);//centroid of first layer
CR=mass_frac/dist;
end_c_loop(c,t)
but I don't know which macros to use even if I looked up the help document. And I also wander how can I do to display the contour of CR.
Anyone can give me some advice?
Thanks.
zhixin is offline   Reply With Quote
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
Grid Macros for UDF elena FLUENT 0 May 9, 2006 09:44
UDF Macros tom FLUENT 1 April 26, 2006 06:40
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
