Help! injection loop has no effect
Old   March 4, 2016, 09:38
Arrow Help! injection loop has no effect
Weijia Qian
Weijia Qian is on a distinguished road
Hi! i hope somebody could help me.
i want to loop between injections and modify them. but it seems that the loop has no effect.
the udf listed below can be built, loaded and hooked. there are two injections but the results show only one.
#include "udf.h"
DEFINE_ADJUST(particle,d)
Injection *Ilist;
Injection *I;
Ilist=Get_dpm_injections();
loop(I,Ilist)
Message("Initializing Injection qwj: %s\n",I->name);
Weijia Qian is offline   Reply With Quote
Old   March 5, 2016, 03:11
Weijia Qian
why the "loop" has no effect?
Old   March 8, 2016, 18:19
`e`
`e` is on a distinguished road
Are you sure you have two injections shown in the injection list? If you're using unsteady tracking, also check that your particles are injected at the current simulation time.
`e` is offline   Reply With Quote
Old   March 8, 2016, 23:00
Weijia Qian
Think you very much! But i have to say sorry.
I think UDF cannot create a particle when need in the solving process. therefore, i have to give up the Fluent approach and turn to OpenFOAM.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
injection problem Mark New FLUENT 0 August 4, 2013 02:30
loop over all injection streams in order to get the particles specifications alighaffari Fluent UDF and Scheme Programming 0 August 28, 2012 02:42
loop over all injection streams alighaffari Main CFD Forum 1 August 27, 2012 17:00
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
