what is the syntax for writing inverse hyperbolic functions in UDFs ANSYS FLUENT
Old   March 1, 2016, 03:05
Default what is the syntax for writing inverse hyperbolic functions in UDFs ANSYS FLUENT
krishna murthy
murthya3 is on a distinguished road
hi
i am writing a UDF(FLUENT) for VISCOSITY, in which the equation contains inverse hyperbolic function of sin. what is the syntax for the inverse hyperbolic functions.
Thanks in advance
murthya3 is offline   Reply With Quote
Old   March 1, 2016, 05:30
`e`
`e` is on a distinguished road
The function for the inverse hyperbolic function of sin is asinh(x), and you may need to include the math library:
#include "math.h"
`e` is offline   Reply With Quote
Old   March 1, 2016, 08:28
krishna murthy
#include "math.h"
thanks 'e'
although, i add math library to my UDF i am getting error like" unresolved external symbol asinh referenced in function cell_viscosity", any library i need to add?
the usage of 'asinh' in the following equation
Flow_stress=(1/alpha)*(asinh(pow((Z/A),(1/n))));
Old   March 1, 2016, 17:19
`e`
I've tested the asinh function with and without including the math header file and it worked fine both times (possibly this function is included elsewhere in Fluent as well). First, add trailing dots to your numbers (for example, "1.") so the fractions aren't rounded incorrectly. Second, try solving a simpler number: asinh(5) which should return 2.31...
I've now tried interpreting the UDF and it's returning the same error. Compile your UDFs.
Old   March 2, 2016, 01:59
krishna murthy
Thanks 'e'
i have tried everything what you have posted. still i am getting same error. Here i am posting my program please tell me where i made mistake.
and also i am getting error: 'not all control paths return a value'
Old   March 2, 2016, 10:13
Bruno Machado
Bruno Machado is on a distinguished road
Originally Posted by murthya3 View Post
Thanks 'e'
This is the program for creating viscosity for a material
#include "udf.h"
#include "math.h"
#define Q 232560.0 //J/mol
#define A 7.86e+06
#define n 5.37
#define R 8.314 //J/molK
#define alpha 0.038e-06
#define Temp 578.5 //K
DEFINE_PROPERTY(cell_viscosity,c,t)
double mu_lam;
double strain;
double Z;
double Flow_stress;
begin_c_loop(c,t)
strain = C_STRAIN_RATE_MAG(c,t);
Z=strain*exp(Q/(R*Temp));
Flow_stress=(1./alpha)*(asinh(pow((Z/A),(1./n))));
mu_lam = Flow_stress/(3.*strain);
if(mu_lam>0)
return;
else
return 0;
end_c_loop(c,t)
you are returning nothing. i think you want it to be
return Flow_stress;
Bruno Machado is offline   Reply With Quote
Old   March 2, 2016, 10:47
krishna murthy
return Flow_stress;
not flow stress, i should get viscosity(mu_lam), hence return mu_lam, is it wrong?
i have written logarithamic formula for an inverse hyperbolic sine function, but while running it flow is getting reversed, without UDF which means with a constant value of viscosity flow is taking place by keeping boundary conditions same. What would be the reason?
Thanks.
Old   March 2, 2016, 10:49
Bruno Machado
not flow stress i should get viscosity(mu_lam), hence return mu_lam, is it wrong?
yes, sorry. type it quickly and did not realize it was wrong. you should return the mu_lam value.
return mu_lam;
Old   March 2, 2016, 15:04
krishna murthy
return mu_lam;
Thanks, Bruno Machado;
yes I did it, and the flow is reversed as stated in previous post.
is that program is correct for getting strain rate from each cell, evaluating viscosity and assigning viscosity to the cell?
Old   March 2, 2016, 16:35
`e`
If you're still getting that same error, try compiling your UDF.
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
UDF Defining in ANSYS FLUENT 16.2 in Win 10 Sadegh.A Fluent UDF and Scheme Programming 11 February 15, 2017 15:45
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
