UDF to change speed of fan
Old   February 21, 2016, 03:32
Default UDF to change speed of fan
AH
visitor is on a distinguished road
Dear sirs/madams
Tried to use the following code to increment fan speed. I did not think that the inlet_mf matters, but it sounds like it does. Entered in cell-zone, mesh motion, speed field; inlet_mf.
Error message; shaftchip-exec: inlet_mf: wrong return type: double udf function expectedchip-exec: ...
Any suggestions please? Thanks in advance.
#include "udf.h"
DEFINE_PROFILE(inlet_mf,thread,i)
float t = CURRENT_TIME;
face_t f;
begin_f_loop(f, thread)
F_PROFILE(f,thread,i) = t*5;
end_f_loop(f,thread)
visitor is offline   Reply With Quote
Old   February 29, 2016, 18:21
`e`
`e` is on a distinguished road
Are you using the moving/deforming mesh model? The DEFINE_PROFILE macro is for specifying a boundary condition such as a developed inlet velocity. Are you modelling the fan or are you simply altering the inlet conditions of a boundary face?
`e` is offline   Reply With Quote
UDF to change heat transfer coefficient with wall temperature emmkell Fluent UDF and Scheme Programming 18 August 7, 2018 04:44
Phase change UDF rampal Fluent UDF and Scheme Programming 7 January 28, 2017 00:00
Use UDF to change the attack angle of flow over 3D wing nvtrieu Fluent UDF and Scheme Programming 8 June 26, 2016 06:53
UDF pressure jump over a fan Bell X Fluent UDF and Scheme Programming 1 April 13, 2015 05:05
I want to Change Values in Existing UDF to Match my Model mamkol Fluent UDF and Scheme Programming 1 April 26, 2013 03:57
