Error in Zone motion
Old   February 19, 2016, 01:46
Exclamation Error in Zone motion
shivakumar is on a distinguished road
Hi all,
I have been working on motion of fluid in side the aircraft drop tank. For my initial case fluid is moving to and fro. For this case I used the following code but is yeilding error. what is the problem? Any help would be greatly appreciated.
#include "udf.h"
DEFINE_ZONE_MOTION(fmotion, omega, axis, origin, velocity, time, dtime)
if(time<10)
omega = 10;
else
omega=0;
N3V_D(velocity,=,0.05*sin(omega*time), 0.0, 0.0);
Error reads
..\src\motion.c(14): warning: not enough actual motion parameters for macro 'NV_D'
..\src\motion.c(14): error C2109 subscripts requires pointer or error type
Thank you
shivakumar is offline   Reply With Quote
Old   February 19, 2016, 12:08
pakk will become famous soon enough
In DEFINE_ZONE_MOTION, omega is a pointer. To assign a rotation, your code should be
*omega = 10;
Note the extra star.
I think this also causes your later problem: you try to take the sine of the pointer, where you should take the sine of the value.
N3V_D(velocity,=,0.05*sin(*omega*time), 0.0, 0.0);
Again, note the extra star.
pakk is offline   Reply With Quote
Old   February 19, 2016, 13:51
Unhappy
Dear pakk,
Thank you for the reply. I just tried with the same code but this time no. of errors have been increased.
#include "udf.h"
DEFIINE_ZONE_MOTION(fmotion, omega, axis, origin, velocity, time, dtime)
	if(time<10)
		*omega=10;
	else
		*omega=0;
Errors are
udf_names.c and user_nt.udf files in 3ddp_node are upto date.
(system "copy "C:\PROGRA~1\ANSYSI~2\v150\fluent"\fluent15.0.0\sr c\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3ddp_node")# Generating ud_io1.h
zone_motion.c
..\..\src\zone_motion.c(7) : error C2100: illegal indirection
..\..\src\zone_motion.c(11) : error C2100: illegal indirection
..\..\src\zone_motion.c(14) : error C2109: subscript requires array or pointer type
..\..\src\zone_motion.c(14) : error C2100: illegal indirection
Done.
Also i tried it in another way, For Example
Int x;
int *omega;
omega=&x
and this too didnt work.
Thank you
Old   March 20, 2016, 05:00
Smile
I solved this problem with DEFINE_SOURCE. I'm moving to the next case i.e, accelerating the Drop tank using the same macro.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
